Lugnut torque specs?
Old Jun 10, 2004 | 08:20 AM
Bull's Avatar
Default Lugnut torque specs?
What should the lugnuts on 96 Hatch be torqued to?
Old Jun 10, 2004 | 08:23 AM
skip.two's Avatar
Default Re: Lugnut torque specs? (Bull)
82 i think. might have been 88. i dont remember.
Old Jun 10, 2004 | 08:25 AM
OnePointFive's Avatar
overrated.
Default Re: Lugnut torque specs? (jL iLLuZiOnz 9)
I torque mine to 85.
Old Jun 10, 2004 | 08:28 AM
bonta-kun's Avatar
Default Re: Lugnut torque specs? (OnePointFive)
84 the manual says 82 if i remember correctly
Old Jun 10, 2004 | 08:30 AM
skip.two's Avatar
Default Re: Lugnut torque specs? (bonta-kun)
i usually torque mine to 82, but if i dont have a torque wrench around, i just do hand tight.
Old Jun 10, 2004 | 09:32 AM
-Trinitron-'s Avatar
They arent supposed to be too tight...thats why they give you a short *** lug wrench to change your flat tires with.
Old Jun 10, 2004 | 10:41 AM
underpressure02's Avatar
I tq all my lugs to 90 ft lbs. I have yet to have a problem been doing it for 10 years that way.
Old Jun 10, 2004 | 10:44 AM
cre18's Avatar
Default Re: Lugnut torque specs? (underpressure02)
stock is 80
Old Jun 10, 2004 | 10:46 AM
RangerHatch's Avatar
Yea the manual is 80 but anywhere between 80-90 are not bad at all. You wont do any damage if your in between those specs.
Modified by RangerHatch at 9:45 PM 6/24/2004
Old Jun 10, 2004 | 10:58 AM
jerbear!'s Avatar
i just jump on the wrench a couple times and call it a day
Old Jun 10, 2004 | 11:14 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">82 i think. might have been 88. i dont remember.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonta-kun &raquo;</TD></TR><TR><TD CLASS="quote">84 the manual says 82 if i remember correctly </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RangerHatch &raquo;</TD></TR><TR><TD CLASS="quote">Yea the manual is 84 but anywhere between 80-90 are not bad at all. You wont do any damage if your in between those specs. </TD></TR></TABLE>
Where are you guys getting these numbers from? Honda reccomends 80 lb-ft.
Old Jun 10, 2004 | 12:17 PM
kommon_sense's Avatar
Default Re: Lugnut torque specs? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Where are you guys getting these numbers from? Honda reccomends 80 lb-ft.</TD></TR></TABLE>
every manual that I've seen clearly states 80ft-lbs.
Old Jun 10, 2004 | 12:29 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Lugnut torque specs? (kommon_sense)
blue torque stick
Old Jun 10, 2004 | 01:31 PM
Deemeetree's Avatar
Electrician
I just tighten them by hand. A little force until I feel enough "stress" on the lug.
Old Jun 10, 2004 | 01:50 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (-TRINiTRON-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -TRINiTRON- &raquo;</TD></TR><TR><TD CLASS="quote">They arent supposed to be too tight...thats why they give you a short *** lug wrench to change your flat tires with.</TD></TR></TABLE>
No they don't! They give you a small lug wrench so it fits in your spare tire well or trunk lining easily.
If anyone cares Honda recommends 80 lb/ft. Any of the figures loosely being thrown around will work though.
Old Jun 10, 2004 | 02:03 PM
IWearMyKswiss's Avatar
New User
Default Re: (Mr Milano)
80 lbs/ft
816d16
Aug 15, 2020 04:41 PM
TypeRuz
Aug 25, 2013 01:41 PM
Dkahn18
Feb 15, 2009 08:35 PM
Dangger
Sep 22, 2006 05:41 PM
93CamaroLT1
May 31, 2006 06:57 PM
