swapped..now car wont start. NEED HELP
ok i will give you all the info. i swapped a OBD1 B18C1 into my 97 Civic Ex. i used the obd2 harness w/the conversion harness for the OBD1 ecu. I am using an obd2 ITR distr. and re wired in the OBD1 injector clips to use those injectors. My problem is the fuel is going to the fuel rail but the injectors are not spraying any fuel so i cant get it to start. i have checked everything...all grounds,spark,fuel, its just not spraying fuel... I really need to get this thing running. any tips or help would be appreciated. thanks!
0930_SI
84
Jul 6, 2011 02:29 PM
buffgsr
13
May 1, 2010 02:12 PM
Kusai.Nihonjin.Desu
21
Apr 16, 2005 08:08 PM
