am i ready for my zex kit install??
Old Jun 10, 2004 | 01:01 AM
hondaeg8's Avatar
Default am i ready for my zex kit install??
here's what i got:
jdm b18c3 motor in an eg hatch
zex dry kit with a 60 shot
bkr7e-11 spark plugs.....haven't set the gap yet...need suggestions
msd sci ignition set up
walbro 255lph fuel pump
b&m fuel pressure riser.......will set fuel pressure at 48psi at idle
kenji chipped p28 ecu. this is the only thing i'm worried about. i don't know about the advance timing this ecu may give. i'm going to e-mail kenji and ask what program he put in the ecu and see if it advances the timing. i was going to retard the timing from the distributor and set it at 14 degrees. i will also be using 93 octane gas like i always do.
what do you guys think.....any suggestions or opinions?
Old Jun 10, 2004 | 06:18 AM
m R g S r's Avatar
Default Re: am i ready for my zex kit install?? (hondaeg8)
I'm not positive, but I think those plugs come pre gapped. You might as well check them anyway. Check that ECU programming and you should be all set. Everything else looks fine.
Old Jun 10, 2004 | 07:24 AM
DaX's Avatar
DaX
Loved
Community Favorite
The -11 on the plug means pregapped to .044". I bought some BKR7E's [no -11] and they came pregapped to .035".
Old Jun 10, 2004 | 12:59 PM
hondaeg8's Avatar
any suggestion on what i should gap the plugs to? i will be using an msd sci kit.
Old Jun 11, 2004 | 07:30 PM
hondaeg8's Avatar
anyone else?
Old Jun 15, 2004 | 05:22 PM
hondaeg8's Avatar
any suggestions on the plug gap? would .032 be okay for a 55-65 shot.
just hooked up my msd stuff last night.
Old Jun 17, 2004 | 01:50 AM
hondaeg8's Avatar
:thumbuo:
brixity
Feb 6, 2005 06:37 PM
sikcivic95
Nov 21, 2004 03:04 AM
DarkBB4
Nov 4, 2004 10:13 AM
91integraLSVTEC
Jan 3, 2004 05:48 PM
98Kord
Jun 26, 2003 07:23 AM
