help..!!! wiring problems
Old Jun 9, 2004 | 11:48 PM
EeeJayEight's Avatar
Default help..!!! wiring problems
i bought some aftermarket injector pigtails (the clips with the wires on them) and i dont know which wire i should hook up to the injector resistor box for my MPFI swap..i searched...but since the two wires on these plugs are idenctical...which one is it?
Old Jun 11, 2004 | 02:22 PM
nikitad's Avatar
Default Re: help..!!! wiring problems (wHiTe91hAtChBaCk)
If you look at the plug from the side where injector plugs in, and turn it such a way that the half-round cut-out is facing up, then it's the right pin (wires are behind, that's why I'm naming pins instead). Than pin goes to resistor box.
Old Jun 11, 2004 | 03:14 PM
4drEF's Avatar
Keyboard Humorist
If you have the pigtails you will see that each injector plug has one wire that is the same color on every plug. I believe the wire is RED. That one goes to the injector resistor box.
Dec 13, 2006 08:52 AM
vladd
Aug 4, 2006 04:28 PM
Project92Hatch
Feb 16, 2004 03:46 PM
jdmcivicferio
May 6, 2003 10:53 PM
bruthaboost
Dec 17, 2001 09:08 PM
