ARP head studs
Old Jun 9, 2004 | 03:48 PM
unknown2's Avatar
Default ARP head studs
For ARP head studs i dont have any lube left wondering if theres any other lubes i could use? thanks BOb
Old Jun 9, 2004 | 04:41 PM
nickgmiller04's Avatar
Default Re: ARP head studs (unknown2)
KY???
serioiusly, ive never built a motor before but i think you need assembly lube. if your in an emergency, some motor oil may work. but again im not saying it will work because ive never taken my motor apart and thats just an idea..
Old Jun 9, 2004 | 05:06 PM
thad
Guest
Posts: n/a
the box comes with torque specs for ARP moly lube, standard assembly lube and motor oil, there is a different spec for each, if you lost the specs check online.
Old Jun 9, 2004 | 06:45 PM
chrisCNL's Avatar
Maybe you can try the moly lube from Napa Auto Parts. It's not as thick as the ARP moly lube but is thicker than regular engine oil. I used it many times to put my drag motor together and for cam installations. I get the part number for you if you need it.
Old Jun 10, 2004 | 04:37 PM
Rocket's Avatar
Default Re: ARP head studs (chrisCNL)
PM me and I'll send you a packet.
Old Jun 13, 2004 | 08:30 PM
HYBRIDSIRACCORD's Avatar
it says to just use the ARP lube. Not sure if i'd use any other lube on them. Installed mine this morning!
Old Jun 13, 2004 | 08:56 PM
dfoxengr's Avatar
Default Re: (HYBRIDSIRACCORD)
you can use motor oil ive read but id be hesitant. just gotta toque down like 7lbs more with that method
SPOOLINmatt
Feb 10, 2013 06:29 AM
hybrid1990crx
11
Feb 20, 2009 02:00 PM
crvtkllr
Mar 29, 2007 01:00 PM
HamiltonRex
Jul 5, 2006 06:55 PM
junior40er
Jun 20, 2006 09:35 AM
