the freakin crankshaft pully wont come off
Old Jun 9, 2004 | 03:08 PM
importlegions's Avatar
Default the freakin crankshaft pully wont come off
im trying to replace my timing belt and i cant get hte crankshaft pully to come loose, and i dont have air tools. does ne body kno a way to take it off?
Old Jun 9, 2004 | 03:58 PM
Default Re: the freakin crankshaft pully wont come off (importlegions)
any body at all?
Old Jun 9, 2004 | 04:29 PM
JDMotive's Avatar
jack up the car high and use a really long breaker bar...
Old Jun 9, 2004 | 04:51 PM
92bubblesi's Avatar
If you know someone with air tools you can have the person break it loose and put it back on for you. It should not be siezed up by the time you get it back home. Thats what I had to do once. Good luck. The crank pulley has keep me from getting things done numerous times. Even when I slid a 4 foot cheater pipe onto a breaker bar.
Old Jun 9, 2004 | 07:28 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importlegions &raquo;</TD></TR><TR><TD CLASS="quote">im trying to replace my timing belt and i cant get hte crankshaft pully to come loose, and i dont have air tools. does ne body kno a way to take it off? </TD></TR></TABLE>
you don't need air tools, all you need is this: http://www.thetoolwarehouse.net/shop/SP-60100.html , raise car to the max floor jack will allow, 3 ft cheater bar, and some good ol' fashion MUSCLE.
Old Jun 11, 2004 | 01:03 PM
does any one know of a way to keep the pulley still so the bolt will be able to be turned?
Old Jun 11, 2004 | 02:10 PM
92bubblesi's Avatar
Default Re: (importlegions)
The previous post shows the tool you need. You can also go the ghetto way and take the starter out and hold the fly wheel with a pry bar. I would recommend the tool posted above.
Old Jun 11, 2004 | 07:33 PM
ttownrex's Avatar
Get a torch (you can buy the kit from a hardware store for $20 and put it to the pulley until it turns red if you have air tools it will come right off. If you dont there is a special tool that you need.
Romo Pyro
Jan 31, 2010 10:53 AM
Bruce Banner
Jan 28, 2007 04:20 PM
crxnonvtec
Dec 21, 2006 12:04 PM
optoomistic
Nov 1, 2003 09:27 PM
GQ 05YellowEVO8
Apr 12, 2003 10:53 PM
