Converting to braided fuel lines. What to do with firewall fitting.
Old Jun 9, 2004 | 02:23 PM
Haberdasher's Avatar
Default Converting to braided fuel lines. What to do with firewall fitting.
So when my turbo was installed the shop hacked off the stock fitting at the firewall and put a braided line on it and secured it with hose clamps.
Now I'm trying to figure out how to correct this and convert it to a more secure setup with threaded fittings. I can't figure out how to get a fitting onto the fuel pipe that sticks out of the firewall. Could I flare the end of the pipe and put a fitting on it? How have other people solved this problem?
TIA
Old Jun 9, 2004 | 02:30 PM
stizzit's Avatar
Default Re: Converting to braided fuel lines. What to do with firewall fitting. (Haberdasher)
IMO, there isn't really a much better way than what the shop did. Most of the people i know with aftermarket fuel rails have this exact same setup.
You could use a compression fitting but it may still leak.
the BEST way is to run the line all the way back to the tank however that is costly and you have to use the right type of line and secure it so it won't chafe.
Anyone have any other suggestions?
Old Jun 9, 2004 | 02:35 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Converting to braided fuel lines. What to do with firewall fitting. (stizzit)
Stan's kit that goes to the stock fuel return looks like this:
Maybe you can ask him how it hooks up.
Old Jun 9, 2004 | 03:10 PM
Flamenco-T's Avatar
Default Re: Converting to braided fuel lines. What to do with firewall fitting. (DaX)
You can use a tube/nut assembly. We do have all the sizes in stock. You can pick up a flaring tool for about 20-30 bucks. Then you can use a -6 or -8AN connector to the stainless braided lines.
We do it all the tiem for our customers.
thanks
Stan
danteisme
Jul 23, 2015 02:49 PM
carlos8
Jun 8, 2015 07:15 PM
Charlie Moua
Mar 22, 2013 05:17 PM
1QwIkEf
Jan 28, 2006 05:05 PM
95hybridcivic
Jan 27, 2003 09:23 AM
