head gasket ???? Did it blow or did the head lift???
Old Jun 8, 2004 | 07:45 PM
b18cx's Avatar
Default head gasket ???? Did it blow or did the head lift???
Thought I would post a few pics of the head gasket to get some opinions on it. Cant tell if the head lifted, bad gasket, or it just gave out.
Freash built motor, AEBS sleeves, GE 83mm headgasket, AEBS head studs.
Yes, before assembly, the head was surfaced, the block was decked, the head studs were installed per AEBS instructions (10ftlbs on the studs/ 2 step torque to final)
I'm leaning to to the head lifting, but I could be wrong. After initial break in, took the car to the dyno. after about 10 runs (with cool down time) and the boost reaching 18psi, the over flow bottle started spewing and the lower radiator hose started swelling. outside the motor was completely dry.
Going to go ahead get anothe GE headgasket and use some copper spray. Leaning twards the ARP head studs. Just dont feel comfortable re-using the AEBS.
Comments/opinions welcome.
Old Jun 8, 2004 | 08:06 PM
JDMH22HATCH's Avatar
Default Re: head gasket ???? Did it blow or did the head lift??? (b18cx)
Damn Eric, I didn't realize this happened until after you left today. I guess both of us had bad luck on the dyno today
Old Jun 8, 2004 | 08:08 PM
b18cx's Avatar
Default Re: head gasket ???? Did it blow or did the head lift??? (JDMH22HATCH)
What happened with your car??
Old Jun 8, 2004 | 08:20 PM
Truthfully none of us have a clue what was going on. Here's the post Eric. Hopefully you'll have some good insight into it, cause I'm sure as hell lost https://honda-tech.com/zerothread?id=889813
Old Jun 8, 2004 | 08:22 PM
salt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cx &raquo;</TD></TR><TR><TD CLASS="quote">Thought I would post a few pics of the head gasket to get some opinions on it. Cant tell if the head lifted, bad gasket, or it just gave out.
Do you have 82.5mm pistons ? what is 10ft/lbs 2 step method ? In contrast I use ARP studs with 68 ft/lbs with 10w30 and copper spray. I have had no head sealing issues. I run 1 bar on on a sc61 on 94 octane.
In the pictures its hard to tell, but I didn't see any head gasket failure. Most of the black coating peels off when you take the gasket off.
Old Jun 9, 2004 | 08:49 AM
b18cx's Avatar
Any thoughts??
In the pics, you can see that some of the head gasket material has gone missing like it was tore off or burnt off.
Old Jun 9, 2004 | 08:59 AM
Didn't this happen one or two runs before it was pulled off the dyno? But it does look like it maybe lifted and then went by the gasket cause the burn off marks are around portions of three cylinders. Was the motor just put together before you dynoed yesterday? Had it been run previously? I know you were saying it was a new build
Old Jun 9, 2004 | 09:21 AM
b18cx's Avatar
We pulled it off the dyno because of the radiator hose swelling. That right there told us there was a problem.
No previous runs the motor had about 50-60 miles on it for the initial break-in.
It only appears to have have gone on the outside edge of #1. the rest og the headgasket looks to be in noemal condition.
Old Jun 9, 2004 | 02:57 PM
Redwidow's Avatar
It does look like there was something 75% around the stud hole location which made the head not completely seat on cylinder #1. Check Third pic from top... Has to be the problem...
Old Jun 9, 2004 | 04:47 PM
danl's Avatar
Banned
Default Re: head gasket ???? Did it blow or did the head lift??? (Redwidow)
Is it possible anything was interfering from the head when you were clamping down the bolts. Reason I say this is I use stock head bolts on my eclipse and run about 22-25psi boost and have been doing so for 2 years. Can stock head bolts be better than new AEBS studs?
Old Jun 9, 2004 | 05:11 PM
MachAF's Avatar
drop the cash on the ARPs.
Old Jun 9, 2004 | 06:39 PM
Jared's Avatar
Default Re: head gasket ???? Did it blow or did the head lift??? (MachAF)
check the head for straightness, i'd have no problems reusing the studs, that is supposedly an advantage to studs is that you can reuse them. anyway, is it possible your dowl pin is too long on that end?
Old Jun 9, 2004 | 09:13 PM
b18cx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redwidow &raquo;</TD></TR><TR><TD CLASS="quote">It does look like there was something 75% around the stud hole location which made the head not completely seat on cylinder #1. Check Third pic from top... Has to be the problem...</TD></TR></TABLE>
Was thinking the same thing untill I compared it to a new/still in package OEM headgasket an it has the same semi-circle impression on that same location. It honestly looks to have been a bad gasket or the studs stretched.
ARP's have been ordered, just to be safe and a new gasket from GE is on the way. Taking the head over to the machine shop to have it double checked and the block will be double checked this weekend.
oh, by the way, it lifted at 483whp at about 8000rpm. Were not done yet
Old Jun 10, 2004 | 02:53 PM
Redwidow's Avatar
Get The O ring Like Mine......http://www.we-todd-did-racing....D.jpg Won't happen again unless you push over 1000HP
Old Jun 10, 2004 | 03:31 PM
danl's Avatar
Banned
Default Re: head gasket ???? Did it blow or did the head lift??? (jerseykid609)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">
Your Eclipse is nothing liek a honda so there is no comparason there get that outta your head. Stock honda head bolts suck one u start making power.. </TD></TR></TABLE>
I'm comparing my stockers to AEBS. My stockers should NOT be stronger than them. SO the ones he has should be fine.
Vtec04
Engine Machining & Assembly
11
Oct 31, 2017 09:26 AM
ChRiS_p123
Apr 8, 2010 10:27 PM
hawaii_boi_808
Jun 20, 2008 09:17 PM
austincrx
Sep 7, 2006 09:49 AM
K20 EG
May 12, 2003 08:43 PM
