New valve cover gasket, leaks WTF?
Old Jun 8, 2004 | 02:57 PM
4crx4me's Avatar
Default New valve cover gasket, leaks WTF?
Just replaced the valve cover gasket and plug o-rings.
But it STILL leaks.... what gives?
I didn't use any gasket sealer, could that be it?
Helms doesn't say anything about sealer, so I didn't bother.
But now I'm wondering if that was smart.
Old Jun 8, 2004 | 02:58 PM
EL Vap133's Avatar
Default Re: New valve cover gasket, leaks WTF? (4crx4me)
Did you pinch it somehow?
Old Jun 8, 2004 | 03:00 PM
APEX CRX's Avatar
I usually put a little Hondabond on a new gasket, especially if its a B-series (around pass side). plus you have to be careful not to over tighten them
Old Jun 8, 2004 | 03:04 PM
hahahahhah's Avatar
Default Re: New valve cover gasket, leaks WTF? (APEX CRX)
Did you check behind the valve cover, make sure none of the gasket fell out of place when you seated the vavle cover? Always a good idea to take a small mirror after installing the vavle cover gasket and using it to see the back of the cover.. make sure nothing is out of line.
-edmCRX
Old Jun 8, 2004 | 03:12 PM
4crx4me's Avatar
Default Re: New valve cover gasket, leaks WTF? (edmCRX)
Thanks everybody, I'll check those things.
D16A6, driver side, front corner just behind the cam pulley seems to the wettest spot. Back looks completely dry.
Old Jun 8, 2004 | 03:16 PM
96-EJ6 B18C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">Just replaced the valve cover gasket and plug o-rings.
Honda Bond oWns you!!!
You have to use it on the "sharp" parts of the gasket...like where it meets the top of the head at the corners of the cam. If your plug o-rings are leaking I would use some Honda Bond on those too.
Old Jun 8, 2004 | 03:23 PM
RCautoworks's Avatar
Default Re: New valve cover gasket, leaks WTF? (96-EJ6 B18C)
In my helms I'm pretty sure it says to place some Honda bond on the corners. Yep, just read the crx manual and I could not find the valve cover section but I looked in the 2000 civic helms and your suppose to apply liquid gasket at the 4 corners.
budget
Feb 16, 2007 01:22 PM
miksew
13
Oct 20, 2006 05:48 PM
Tazragoon
Oct 19, 2006 01:53 PM
type Gendy
10
Sep 6, 2003 10:44 AM
B18C-Hatch
May 19, 2003 02:44 PM
