special tools to change clutch?
Old Jun 8, 2004 | 02:12 PM
7808's Avatar
Default special tools to change clutch?
last night i was kinda drunk messin around with a friend and i knew my clutch was beat in my 90 civic dx hatch, anyways when i sober up today and drive it it barely grabs 2nd and 3rd at all,
do i need any special tools to change my clutch? i'll probly get one off ebay, and i never changed one before so any tips are welcome
Old Jun 8, 2004 | 02:16 PM
APEX CRX's Avatar
Default Re: special tools to change clutch? (fuctup)
If you already have a good selection of Metric tools then only things I can think of is a flywheel holding tool if you need to get it off to resurface and a 8mm pin punch for the bitch pin on the linkage.
Old Jun 8, 2004 | 02:21 PM
91civicDXdude's Avatar
use a flat screwdriver to hold the flywheel and unbolt the linkage from the shifter.
Old Jun 8, 2004 | 02:29 PM
96-EJ6 B18C's Avatar
Default Re: (91civicDXdude)
12 point 10mm socket for the pressure plate and a good torque wrench.
EDIT: 32MM socket for the axle nut and a bad *** impact gun or long breaker bar.
mjf6866
Mar 9, 2014 07:08 AM
4NOWJUSTADX
Oct 20, 2005 07:06 PM
Sick'Lude
Jun 22, 2005 01:42 PM
snatch
16
Aug 11, 2004 08:16 PM
tilt
Dec 6, 2002 08:54 AM
