Greddy Timing Belt
Old Jun 7, 2004 | 07:03 PM
bigslimdog's Avatar
Default Greddy Timing Belt
Anyone using one of these? Are there any benefits over the OEM timing belt?
Old Jun 7, 2004 | 07:10 PM
antiJDM's Avatar
Default Re: Greddy Timing Belt (bigslimdog)
if you have like 500 hp
Old Jun 7, 2004 | 07:19 PM
bigslimdog's Avatar
Default Re: Greddy Timing Belt (2thousandcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2thousandcivic &raquo;</TD></TR><TR><TD CLASS="quote">if you have like 500 hp</TD></TR></TABLE>
That didn't answer my question.
Old Jun 7, 2004 | 07:20 PM
Deemeetree's Avatar
Electrician
Maybe he's trying to say that IF you have 500hp or more, you'll need the Greddy one because it's m4d tYt3 JDM y0 timing belt made SPECIFICALLY for high horsepower engines? Not sure.
antiJDM's Avatar
well the only benefits of it would be if you were running a very high hp motor, use your money towards somethin else, oem is by far well enough to support up towards 250 hp
Old Jun 7, 2004 | 07:22 PM
bigslimdog's Avatar
Default Re: (2thousandcivic)
Thanks
Old Jun 7, 2004 | 07:29 PM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2thousandcivic &raquo;</TD></TR><TR><TD CLASS="quote">well the only benefits of it would be if you were running a very high hp motor, use your money towards somethin else, oem is by far well enough to support up towards 250 hp</TD></TR></TABLE>
or more.seen plenty of much higher HP producing motors using OEM belts.i have yet to see anything that points to these aftermarket timing belts being any better than OEM.staying up on your maintenance schedule is the best way to prevent a timing belt failure.
BUT,those aftermarket belts sure do look JDM with a cut valve cover and some cool cam gears!
Chris
Old Jun 7, 2004 | 07:30 PM
Deemeetree's Avatar
Electrician
IMO, a bling factor. OEM should be good enough.
high_octane
Apr 3, 2008 06:33 AM
all-mtr-teg
10
Oct 22, 2007 01:57 AM
JoN2DaSoNz
Mar 5, 2007 04:10 PM
MujetDereh
Dec 7, 2006 10:36 PM
97 Integra GSR
Jan 21, 2005 09:42 PM
