vacuum line size + vacuum source question..
Old Jun 7, 2004 | 05:39 PM
anguish's Avatar
Default vacuum line size + vacuum source question..
i have my wastegate to a fitting on my compressor outlet. can i T off this line and run it to my BOV or should i run my BOV from somewhere else? and should i use the stock vacuum hose size? (im running a T3-60, 7psi wastegate)
thanks for the help...
Old Jun 7, 2004 | 06:38 PM
Stu's Avatar
Stu
New User
Use a vacuum hose that fits whatever fittings you need it to hook it all up.
Of all the things you want to T from, the wastegate is probably the last one.
Old Jun 7, 2004 | 06:54 PM
Full-Race Javier's Avatar
Default Re: (Stu)
run your bov signal from behind the TB. running a "T" off the the brake booster line (after the check valve) to the bov works well.
Smashback
Mar 12, 2013 02:31 PM
aryiman98civic
Feb 22, 2007 10:13 AM
BodyKits NW
Sep 17, 2003 10:56 PM
echo999
May 1, 2002 08:12 AM
