valve adjustment concern
Old Jun 7, 2004 | 02:45 PM
matix's Avatar
Default valve adjustment concern
I was adjusting my valve for the fisrt time today. I left the plugs in. When i was turning the crank it was hard to turn but made A light hissing sound like it was letting pressure out. Is this normal.
Old Jun 7, 2004 | 09:31 PM
blklude01's Avatar
Default Re: valve adjustment concern (matix)
hey! valve adjustment is done every 30k miles, if valves clearance is too tight it could cause you to burn your valves or it could cause a misfire. And the hissing noise is normal.
Old Jun 29, 2004 | 12:09 PM
SiYouLater's Avatar
the pressure was from leaving your plugs on, if you did it without the plugs it would of been easier.
NEDan
Honda Fit
Aug 4, 2017 06:30 AM
Jagan'92
Feb 1, 2015 10:47 PM
acurateg96
Feb 6, 2006 03:24 AM
dacaveman
Jul 20, 2004 10:02 PM
raene
Jun 27, 2001 10:45 PM
