My short shifter is getting really hot??
Old Jun 6, 2004 | 08:25 PM
gobblebox59's Avatar
Default My short shifter is getting really hot??
Hey guys, a few days ago my short shifter in my 1999 Civic Si started to get really warm and now its like hot when i drive for only like 10 minutes, I'm not sure what to check can you help me out?
Old Jun 6, 2004 | 08:30 PM
dohcdelsol's Avatar
Default Re: My short shifter is getting really hot?? (gobblebox59)
When u did your short shifter, did u happen to remove your heatshield from under the car??? The heat is comming from the exhaust. At least thats what happend when i put one on a teg. ****** burns pretty bad
Luserkid's Avatar
How close is it to your exhaust pipes? Also has this been happening alot or just started like today and you had the shifter for a year? Could just be the heat traveling through the metal.
Old Jun 6, 2004 | 08:33 PM
Two_K Si's Avatar
Default Re: My short shifter is getting really hot?? (Luserkid)
well since the bottom of a short shifter is longer than an OEM one, it will be closer to the exhaust/cat area. It may even be rubbing the exhaust pipes, which is heating it up. You can either bend your hangers on your exhaust to drop it a bit, or you can live with it.
Old Jun 7, 2004 | 04:02 AM
onephatcivic's Avatar
Default Re: My short shifter is getting really hot?? (Two_K Si)
My **** gets hot as hell too, plus I have a Type R shift ****. Its sucks real bad on the trips to the long shows.
Old Jun 7, 2004 | 04:06 AM
xavior66's Avatar
I remember when I had my Skunk2 dual-bend shifter in my Sol, it wasn't really the shift lever itself getting hot, it was the f*ckin' Skunk2 shift ****! I swore that one of these days my hand was gonna have the shift pattern branded onto it eventually.
Old Jun 7, 2004 | 05:16 AM
JDMSiGuy17's Avatar
Default Re: My short shifter is getting really hot?? (xavior66)
Just make sure your heatshield is on because i almost forgot about it too. Mine used to be pretty close to my exhaust but once i got my evo2 on my si its not even close to it anymore. Hope this helps
Old Jun 7, 2004 | 06:17 AM
Cam79's Avatar
Default Re: My short shifter is getting really hot?? (JDMSiGuy17)
Yea my Skunk 2 **** is starting to get hot as **** ive noticed.
CompanyFlow
May 8, 2009 10:33 AM
Frost7177
Jan 17, 2007 09:29 AM
rams2k4rm
Sep 11, 2006 07:49 AM
Abunai
Jul 11, 2002 03:30 AM
crxzc
Jul 2, 2002 05:09 AM
