IACV for JDM B16A
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
IACV for JDM B16A
Supguys, just trying to confirm which USDM car I should order an IACV for to bolt up to my 2nd gen JDM B16A? I know the 99-00 Civic Si has a different bolt pattern. Can anyone say they know it is ___ 100% for sure? I have been told 94 DelSol but I just need confirmation so I don't **** off my local dealer by returning several special order IACVs.
Re: IACV for JDM B16A (HondaFanatic708)
Did you try cleaning out the Idle control with carb cleaner first? Flood it with carb cleaner but leave the coolant tubes dry. That'll save you some money If not, it's just a suggestion
Re: IACV for JDM B16A (Inconclusive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Inconclusive »</TD></TR><TR><TD CLASS="quote">Did you try cleaning out the Idle control with carb cleaner first? Flood it with carb cleaner but leave the coolant tubes dry. That'll save you some money If not, it's just a suggestion </TD></TR></TABLE>
Agreed, this is the exact reason I have one for sale. I thought the IACV was the problem but it wasnt.
Re: IACV for JDM B16A (x-743-x)
I ordered one from a 99-00 SI and the bolt patterns are slightly different. I will try the carb cleaner thing, no sense wasting over $100 if that isn't my problem. Well basically here is my problem. When I start the car it will rev to about 3000 rpm and sit there until it gets warmed up. At that point the idle will surge from normal idel up to 2,500 and back. Someone I work with suggested to replace the IACV and that may correct it. Another friend of mine told me to look at the engine coolant temp sensor. Make sure the is continuity and that the sensor isn't messed up. Has anyone here had any experience with this "issue"? Any help would be greatly appreciated.
Re: IACV for JDM B16A (GapxGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GapxGuy »</TD></TR><TR><TD CLASS="quote"> You can also use single cam ones, they line up.</TD></TR></TABLE>
Yes, but they arent the correct size and will cause idling problems. Dont ask how I know.
Spade
15
05-29-2002 02:31 PM
