advantages to swapping from below?
Old Nov 12, 2001 | 10:36 AM
markedOO1's Avatar
Default advantages to swapping from below?
are there any advantages to swapping an engine in (d16z6) from underneath? I've done em from above and i was thinking that there's alot less to get around coming up from the bottom...thanks
Old Nov 12, 2001 | 11:19 AM
Phatwhippin_CRX's Avatar
Default Re: advantages to swapping from below? (marked001)
When I did my swap, I did it from the bottom.... all I had to do was unbolt the mounts a lower front crossmember........ I dont know exactly any advantages per sae......... but I was certainly much easier than I expected.......
Old Nov 12, 2001 | 11:22 AM
WuShu's Avatar
New User
Default Re: advantages to swapping from below? (Phatwhippin_CRX)
depends on what you have to work with, cherry pickers cheap to rent or buy, not everyone has a lift available.
Old Nov 12, 2001 | 11:29 AM
Trinity's Avatar
Default Re: advantages to swapping from below? (HondaCRX)
i know when they did my engine they dropped it out the bottom and it seems easier that way. just my 2 cents. they had a cherry picker though and they put the other engine in with that
Old Nov 12, 2001 | 11:34 AM
markedOO1's Avatar
I've got a cherry picker... yeah, you can get it up high enough w/ stands and use a cherry picker to lift it through....hhmmm. I dont know. I'll probably go through the top
p.bass
Jan 28, 2014 06:40 AM
92lxsleeper
Feb 17, 2011 03:17 AM
oOJ-GrindOo
Jun 5, 2004 02:00 PM
leonard
Dec 19, 2001 02:11 PM
