Keeping AC with a B16 swap on a 6th gen
Old Jun 5, 2004 | 10:34 PM
FifthGearOnline's Avatar
Default Keeping AC with a B16 swap on a 6th gen
yea yea yea i know "this has been covered, search n00b!"
heres what i have found out searching...everyone has said to use the DelSol DOHC VTEC A/C bracket for EG and EF chassis. I have heard so much conflicting information reguarding keeping a/c on the 6th gen thats why im asking.
do i need the same bracket? or will the stock B16 bracket from the 99-00 SI work with the A/C on my 99 DX
thanks
Old Jun 5, 2004 | 11:07 PM
hatchi's Avatar
Default Re: Keeping AC with a B16 swap on a 6th gen (FifthGearOnline)
you will need to buy the p54 a/c bracket from 94-95 delsol.
Old Jun 5, 2004 | 11:09 PM
99blackcivicSi's Avatar
Default Re: Keeping AC with a B16 swap on a 6th gen (hatchi)
if you buy a 99-00 Si swap the bracket should be on there already that is what you need i woulnd't buy anything else since it was made for a 6th gen civic w/ A/C
Old Jun 6, 2004 | 12:04 AM
Default Re: Keeping AC with a B16 swap on a 6th gen (99blackcivicSi)
thats the kind of info i was trying to figure out....im getting my swap from H motorsonline this summer
Old Jun 6, 2004 | 11:25 AM
bump for a few more looks
Old Jun 6, 2004 | 11:37 AM
BigZ88's Avatar
Default Re: (FifthGearOnline)
i've got a 97 ex, and the b16 AC/ mount did NOT fit the a/c compressor.
you will need the p54 bracket as far as i know. I just took my A/C out, and i live in the south, so i'm suffering....but oh well.
Old Jun 6, 2004 | 12:10 PM
Default Re: (BigZ88)
really.....hmm...ok
Old Jun 6, 2004 | 12:14 PM
pb16b's Avatar
Modified by pb16b at 6:56 AM 7/4/2004
Old Jun 6, 2004 | 06:02 PM
Mr.Hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigZ88 &raquo;</TD></TR><TR><TD CLASS="quote">i've got a 97 ex, and the b16 AC/ mount did NOT fit the a/c compressor.
you will need the p54 bracket as far as i know..</TD></TR></TABLE>
He's right - my 99 was the same. the 99 si p30 DID NOT WORK. only 2 of the holes line up.
Old Jun 6, 2004 | 08:03 PM
Mighty's Avatar
If its a P30 bracket it will not work it has to be the P54.
Old Jun 6, 2004 | 10:52 PM
Default Re: (Mighty)
i have seen some swaps come really complete and had the A/C compressor on it so you may get lucky, IMO i would buy the B series compresser used from someone on here it would be cheaper than the a/c bracket
Old Jun 28, 2004 | 06:37 PM
Default Re: (99blackcivicSi)
one more question......will the stock lines off my Dseries work???
Old Jun 28, 2004 | 08:33 PM
spektrum's Avatar
Get the P54 bracket and call it a day.
I had the P54 bracket in my 96 coupe and I run the P54 bracket in my 97 hatch that I drive now.
Here is the part #:
38930-P54-000
Old Jun 28, 2004 | 09:31 PM
eg crunkmonster's Avatar
Default Re: (pb16b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pb16b &raquo;</TD></TR><TR><TD CLASS="quote">use the s/c bracket off 99-00 si. fit's!</TD></TR></TABLE>\
shut up....you do not know what you are talking about
and a P54 bracket (from a del Sol) is not the only bracket that will work. Order a 97 CRV a/c bracket. Its a P2J or P7J i forget the exact number but it is something like that. Plus this bracket is about $50 cheaper than the P54 bracket. I've been using this bracket in my car for the past year and just ordered another one for my 95 hatch with a B18C1 with stock compressor because my cousin just dropped a b20 into his 99 coupe and needed it cuz my car was off the road for a while.
EDIT: the cheaper CRV bracket part number is: 38930-P7J-000 found it here for $60
http://www.slhondaparts.com/br...AT%29
del sol one is $110
http://www.slhondaparts.com/br...81%29
Modified by eg cookiemonster at 1:47 AM 6/29/2004
Modified by eg cookiemonster at 1:49 AM 6/29/2004
Old Jun 28, 2004 | 09:33 PM
ICEDOWT's Avatar
from what i was told the si mount will not work becuse only two wholes will bolt up and if you the si mount and si compressor it will bolt up but the lines will not fit you would have to get custom lines.
i was told to get a delsol vtec model ac bracket dont know from what year i ordered the one from a 96-97 model i believe dont know if it will work till next week when i do the swap they said this will bolt up to my motor using my stock compressor and lines
Old Jun 28, 2004 | 11:43 PM
ek4hatch's Avatar
Default Re: (ICEDOWT)
if u want power take off!!
if u want it to have a/c and chill install it!!
good luck bro!!
Old Jun 29, 2004 | 02:18 AM
2000DX's Avatar
Default Re: (eg cookiemonster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg cookiemonster &raquo;</TD></TR><TR><TD CLASS="quote">\
del sol one is $110
Modified by eg cookiemonster at 1:49 AM 6/29/2004</TD></TR></TABLE>
Wish I would've known this before I bought they p54.
Old Jun 29, 2004 | 05:37 AM
boostin4drcivic's Avatar
Default Re: (2000DX)
so the crv bracket works with the civic d-series compressor? im about to order a bracket now....lemme know
Old Jun 29, 2004 | 06:46 AM
Shaun's Avatar
what all comes with that CRv bracket for 60$... they dont have pic's of it...... anyone have some pics of the crv bracket?
Old Jun 29, 2004 | 07:04 AM
Default Re: (boostin4drcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostin4drcivic &raquo;</TD></TR><TR><TD CLASS="quote">so the crv bracket works with the civic d-series compressor? im about to order a bracket now....lemme know</TD></TR></TABLE>
Yes, it does work. Im almost 100% sure but I know the 97 one works for sure but they changed the bracket after a certain year so just make sure you order the 97 one.
The bracket comes bare with no bolts or pulleys but u can just use the ones off the single cam bracket i believe
Old Jun 29, 2004 | 03:22 PM
you better be right because thats the one i ordered
Old Jun 30, 2004 | 12:06 AM
ICEDOWT's Avatar
got the p54 in today it works for sure. can somone get me the part number for the crv my friend wants to put ac in his ride too. can somone get a picture of it in the car too see how the lines are run
Old Jun 30, 2004 | 04:05 PM
if you actually READ the thread you will find the part number listed
Old Jun 30, 2004 | 06:53 PM
I just picked up mine today and everything bolted str8 u....Ill up load pix tomorrow of everything since I got the freakin wrong SOHC compressor.....I needed a newer SOHC compressor cuz (94-95) I had a 93 one and the hoses are too small
Old Jun 30, 2004 | 07:14 PM
tallblondkid's Avatar
will the P54 and the crv a/c mount fit the eg also?
