B18C bogging out around low RPM's. Need help please
Old Jun 5, 2004 | 07:57 PM
jonyb's Avatar
Default B18C bogging out around low RPM's. Need help please
JDM ITR B18C motor. All stock with no mods except for the fuel system. AEM rail, FPR, Earl's filter. When you accelerate, it bogs out at low RPM's but stops when you floor it. I've changed the plugs and the wires are new. No CEL. Fuel is at 40 psi on the rail. I also ordered a cap and rotor for the local jackass parts store that does'nt have Honda parts in stock.
Any thoughts or suggestions?
Old Jun 5, 2004 | 08:07 PM
mmuller's Avatar
Mad Scientist
Default Re: B18C bogging out around low RPM's. Need help please (jonyb)
have you checked tps voltage?whats your timing set at?
Old Jun 5, 2004 | 08:21 PM
jonyb's Avatar
Default Re: B18C bogging out around low RPM's. Need help please (mmuller)
sure have'nt. Now that I think of it, I havent' checked the timing. It's been running okay for a while. This just started happening
Old Jun 6, 2004 | 01:47 AM
2k.civic.si's Avatar
sounds to me like your running rich and your plugs have finally loaded up......had same problem....i run 38psi and still had to use my afc to lean out below about 4500rpm....before that i had it at 42psi and it fouled out my plugs rather quickly driving around town like normal....a/f gauge stayed pegged rich at 42psi...very bad
im running a fully built b18c with b16 head...with ctr overbore pistons.....plus all the normal stuff...
Old Jun 6, 2004 | 07:53 AM
jonyb's Avatar
Default Re: B18C bogging out around low RPM's. Need help please (2k.civic.si)
The plugs have been closer to white then showing rich. When I changed the plugs I raised the fuel to 40psi. I was running 37 and that was lean
Old Jun 6, 2004 | 01:31 PM
jonyb's Avatar
Adjusted the timing and that seemed to fix it. I also hooked up an AFR. I used the white wire on the P73, but the AFR shows lean, and sometimes so lean it drops off scale. ???
Old Apr 17, 2006 | 06:12 PM
9WON4's Avatar
i havethe same problem, dude.....'98 jdmb18c EVERYTHING stock........i thought it was IACV but i dont think so anymore.....RPMNYC installed the motor 4 me and it ran perfect ever since....changed plugs wires cap/rotor a clean.....it ssputters a bit it low rpms sometimes, but after you floor it.......pulls great.......help?
Old Apr 18, 2006 | 06:41 AM
9WON4's Avatar
Default Re: B18C bogging out around low RPM's. Need help please (kidkanedtx)
BUMP
Old Apr 18, 2006 | 08:28 AM
9WON4's Avatar
we need info guys
ekcivic2
Dec 21, 2023 06:02 AM
GagnarTheUnruly
Engine Management and Tuning
Sep 23, 2017 07:09 AM
djay86
40
Jun 1, 2011 08:23 PM
cslegacy
Mar 30, 2009 11:10 PM
92eh3si
Feb 19, 2005 06:32 PM
