hard to downshift into 2nd
Old Jun 5, 2004 | 06:10 PM
Unjockable's Avatar
New User
Default hard to downshift into 2nd
i can downshift into any gears but it barely goes into 2nd gear unless i pull down on the shifter HARD. anyone know what the problem is? could the tranny be messed up? it's a b16 tranny. shifts from 1-5 is smooth with no grinds.
Old Jun 5, 2004 | 06:12 PM
STREETWERKZ's Avatar
Default Re: hard to downshift into 2nd (Unjockable)
clutch fluid filled?
sounds like a stupid question, but thats probably it.
Old Jun 5, 2004 | 06:13 PM
clm's Avatar
clm
Default Re: hard to downshift into 2nd (STREETWERKZ)
Could be the synchro, but you did say it shifts fine when upshifting.
Have you tried matching revs?
Unjockable's Avatar
New User
yes, it's filled.
yeah, it's fine when i'm shifting normally from 1-5. matched revs and it's still hard to go into 2nd
Old Jun 5, 2004 | 06:38 PM
otakueric's Avatar
its hard even when you overrev a little?
Old Jun 5, 2004 | 06:48 PM
Unjockable's Avatar
New User
Default Re: hard to downshift into 2nd (otakueric)
yes sir
Old Jun 5, 2004 | 08:21 PM
Unjockable's Avatar
New User
help...
Old Jun 6, 2004 | 11:25 PM
Unjockable's Avatar
New User
btw, when i'm going 20mph, it goes into 2nd easily. i just have to do it twice when i'm going faster.
Old Jun 7, 2004 | 04:32 PM
94CoupeEJ1's Avatar
You didn't change your fluid recently did you? Maybe the fluid is getting low. Many cars wear out the 2nd gear synchro's 1st. They have the most trouble working when you are shifting down. If that's the problem you might try changing the fluid and the fluid to use is GM Synchromesh FM. Just do a search using those words and you will find plenty of testimonials to it's goodness. I switched a couple months back and it really shifts nice.
Old Jun 7, 2004 | 06:18 PM
Unjockable's Avatar
New User
Default Re: hard to downshift into 2nd (94CoupeEJ1)
thanks! how much is a quart of that?
and no, didn't change fluid lately.
Old Jun 7, 2004 | 06:46 PM
duh blacksheep's Avatar
are you rev matching with the clutch out? anyway, i found penzoil syncromesh for 5 bucks a quart at autozone
Old Jun 7, 2004 | 07:13 PM
nonsense's Avatar
Default Re: hard to downshift into 2nd (duh blacksheep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duh blacksheep &raquo;</TD></TR><TR><TD CLASS="quote">are you rev matching with the clutch out? anyway, i found penzoil syncromesh for 5 bucks a quart at autozone</TD></TR></TABLE>
yeah try double clutching (i.e. push in clutch, shift out of 3rd into neutral, clutch out, blip throttle, clutch in, shift into 2nd). It's most likely your 2nd gear syncro. Do you have a short shifter on there?
Try the syncromesh
Old Jun 7, 2004 | 08:10 PM
Unjockable's Avatar
New User
is penzoil syncromesh the same as GM?
no short shifter. and yes, i rev match
Old Jun 7, 2004 | 08:45 PM
crashN2u's Avatar
I had the same problem, but only w/ 4th gear. The problem didn't stop until I replaced the clutch and flywheel.
Old Jun 7, 2004 | 09:11 PM
fishnfst's Avatar
I have the same problem going into second gear on the upshift if I am bumping off of the rev limiter. My d16 synchros are just too small for the power of a boosted D.... The downshift is fine though....
Sorry don't mean to thread jack... And yes I just did a clutch and flywheel and replaced the tranny fluid with oem fluid. Maybe I should try this synchromesh...
Old Jun 10, 2004 | 08:35 PM
crashN2u's Avatar
Default Re: hard to downshift into 2nd (crashN2u)
Forgot to mention, also replaced master cylinder. Don't know if that will help though.
Old Jun 13, 2004 | 11:36 AM
it could be a number of things. shifter linkage bushings, tranny mount, unadjusted cluthch pedal height, bad master cylinder, bad syncro, wrong gear oil, blah blah.
park you car. rev your engine to like 3k with the clutch out, then clutch and shift to 2nd ...does it go in easily?
then cruise at 45mph, pull you gear to neutral and let the clutch out, then clutch in and put the gear into 2nd, how much heavier is that from the first check?
Old Jun 13, 2004 | 01:16 PM
95hondadelsolsi's Avatar
Default Re: hard to downshift into 2nd (clm)
clutch fluid.. or tranny
Old Jul 10, 2004 | 09:38 PM
Unjockable's Avatar
New User
Default Re: hard to downshift into 2nd (95hondadelsolsi)
still having the problem. is the tranny messed up? help please....
Old Jul 10, 2004 | 11:28 PM
C M S's Avatar
Try the GM Synchromesh
$10 a qt, buy 3
Old Jul 10, 2004 | 11:39 PM
mnbv's Avatar
Default Re: hard to downshift into 2nd (1SICJDM)
The helms manual says to use Genuine Honda MTF.
bigsnorlax
Oct 30, 2008 05:11 PM
B16Jacques
Sep 15, 2006 04:06 PM
bluels-t
Dec 13, 2004 12:37 PM
Inextricabledrvr
Jul 5, 2004 05:59 PM
geminis2k
Feb 23, 2003 12:53 PM
