1990 Accord not shifting
Old Jun 5, 2004 | 01:26 PM
windcalmer's Avatar
Default 1990 Accord not shifting
I was driving down the street when the rpms shoot up and the car was no longer in gear. its and Automatic 2.2L LX. I turned the car off for a minute or two then tried again to get it into gear. it shifted into first and after about 20 meters it fell out of gear again. I just replaced the ATCU(trans computer) about a month ago. Any ideas what could be causing this?
Joan
Old Jun 5, 2004 | 01:54 PM
Gresham Accord's's Avatar
Default Re: 1990 Accord not shifting (windcalmer)
sounds like your tranny is going, sounds like 2nd gear is messed up and its not shifting into it so it looses itself
Old Jun 5, 2004 | 04:52 PM
windcalmer's Avatar
Default Re: 1990 Accord not shifting (Gresham Accord's)
Could it be anything other than the trnny going?
Old Jun 5, 2004 | 05:00 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by windcalmer &raquo;</TD></TR><TR><TD CLASS="quote">Could it be anything other than the trnny going?</TD></TR></TABLE>
What does the fluid look like? Is it stinky? Is it full?
Old Jun 6, 2004 | 03:31 PM
windcalmer's Avatar
Default Re: 1990 Accord not shifting (Chiovnidca)
The fluid is full and smells fine. I dont know what tranny fluid should smell like but it doesn't smeel "bad". Does that help?
Joan
Old Jun 6, 2004 | 04:40 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by windcalmer &raquo;</TD></TR><TR><TD CLASS="quote">The fluid is full and smells fine. I dont know what tranny fluid should smell like but it doesn't smeel "bad". Does that help?
Does it start working again after it sits for a while? Does it start acting up after driving 1 to 5 miles?
Old Jun 6, 2004 | 07:18 PM
windcalmer's Avatar
The day it broke down I let it sit for 15min or so and it worked again but only for 20 meters or so then it would fall out of gear. I have not tried it again because i dont want to get stuck away from my house again. Would it work to put the car on jack stands and test it to see if it falls out of gear?
Old Jun 6, 2004 | 07:30 PM
Chiovnidca's Avatar
We used to get some 90 and 91 Accords that the lining for the lock-up clutch would disintegrate. As they were driven the little pieces of clutch material would get caught in the pick-up screen. When enough pieces got caught there they would block the flow of atf and the car wouldn't move. After shutting of the engine for a while, the stuff would drop off and settle to the bottom and the tranny would operate normally until it clogged up again. It usually took about 1 to 5 miles to get them to act up. I havn't seen one doing this for a few years now.
Old Jun 7, 2004 | 08:29 AM
windcalmer's Avatar
Thanks, How hard is that to repair?
joan
Old Jun 7, 2004 | 07:51 PM
hondadude's Avatar
You might want to remove the shift solenoids and look for "trash" in them, also jumper the check connector and see if you have any trans codes...If the trans will work after sitting a few mins, then I'd say the screen is getting plugged up; too bad it's inside the trans. When the torque converters start coming apart they put out a paper mulch looking stuff. If that is your case you might be able to drop the trans pull the case and clean it out, then replace the torque converter.
Old Jun 8, 2004 | 10:00 PM
windcalmer's Avatar
Default Re: 1990 Accord not shifting (hondadude)
Thanks, where are or what do the selinoids look like?
joan
p.s. many thanks guys...
Old Jun 9, 2004 | 10:06 PM
windcalmer's Avatar
Are the selinoids the two round things about two inches long coming out of the top of the top of the tranny?
joan
Old Jun 14, 2004 | 12:59 AM
windcalmer's Avatar
What do the selinoids look like and where are they???
deejae
Nov 16, 2013 02:39 PM
bassichonda96
Feb 26, 2008 04:48 AM
twenty
Dec 1, 2005 06:20 PM
elevatethis
41
Nov 24, 2003 12:02 AM
TrueDC2
Oct 3, 2003 12:13 PM
