need help with idle problem!!!!
I have an idle fluctuation, and it won't stop. It's an Integra LS, and when you start it idles high then drops and just keeps fluctuating. Please help!!!!!!!!!!
Check the PCV valve and vacuum hoses to make sure the valve works and there are no obvious leaks/rips from the hoses, sounds like vacuum builds up and then becomes overbearing on the hose and leaks out, hence the fluctuation. Also check to make sure your idle air screw is adjusted and functioning. If both of those still come up empty, test to see if you're getting spark to all cylinders by pulling each individual plug wire and seeing if the car runs different, if yes, then that's fine, if not, then I guess you're going to need plugs/wires.
ArchAngel Sabastian
Sep 11, 2002 09:29 PM
