bNeed Help, BRAKE QUESTION
Old Jun 4, 2004 | 07:16 PM
90da4dr's Avatar
Loved
Default bNeed Help, BRAKE QUESTION
Hey, I changed my spindle today, I put the rotor, pads, caliper and tire back on. When i started to drive the pads are rubbing against the rotor even when the brakes are off. ( also when i was putting the pads back on, I used the piston tool to push the piston back)
1) How do i fix this?
2) I cant get the nut to the steering rack back on. When i try to tighten the bolt, the screw and the nut turn. I thing the bearing is bad. How do i fix this?
Old Jun 4, 2004 | 08:46 PM
flip b18b's Avatar
Default Re: bNeed Help, BRAKE QUESTION (95civ4dr)
as far as the pads rubbing on the rotor make sure the brake lines are pinched anywhere. witht he bolt on the streering rack try applying force on the top of the bolt i'm pretty sure your are reffering to a ball joint, they tend to be quite a bitch from time to time, but with luk and the right amouint of force fromt he top you'll be able to get the bolt back on
Old Jun 5, 2004 | 10:46 PM
90da4dr's Avatar
Loved
Default Re: bNeed Help, BRAKE QUESTION (flip b18b)
thanks for the reply, i will try to get back to it before the weekend is out
martin31
Suspension & Brakes
Mar 15, 2014 05:26 AM
wgbm92
Suspension & Brakes
Nov 9, 2010 07:02 AM
andylawcc
Dec 22, 2009 04:00 PM
fleetmack
Dec 22, 2004 09:24 AM
integra15
Feb 20, 2002 09:27 AM
