Stripping the interior
Easy! Simply fold your backrest a bit and near the center of both seats, you might see a small bracket. At times there's a 10mm bolt there. If there is, remove it. Next you will need to take a black clip on the outside of each backrest. Once removed, you push the seat towards your panels and slide the back rest forward. Then lift your seat up. You will notice that it hooks onto your frame at the end of the seat (side closer to front of car). Just nudge out of these two holes gently.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tut4u2 »</TD></TR><TR><TD CLASS="quote">I need to take out the back couch of a 1993 Civic Hatchback but I cant find any of the bolts. Does anyone have any tips?
thx</TD></TR></TABLE>
Here is a really detailed thread about this with picks. This is all i needed to take out my rears
EDIT: forgot to post link
https://honda-tech.com/zerothread?id=512901.
rawrjaay
Sep 8, 2011 05:33 PM
bigBOI_92DA9
May 31, 2004 02:20 PM
