Help Quick Please!
Old Jun 4, 2004 | 06:34 PM
pburke23's Avatar
Default Help Quick Please!
Putting on new brake pads today...I put em on, and tightening the bottom caliper bolt back in, i snapped it...do I have to order this bolt from Honda? and any suggestion on getting the small piece of whats left of the bolt out of the caliper?
Old Jun 4, 2004 | 06:57 PM
pburke23's Avatar
Default Re: Help Quick Please! (pburke23)
Does anyone know where i can order just the caliper bolt, and the sliding pin it goes into????
Old Jun 4, 2004 | 07:06 PM
EL Vap133's Avatar
http://www.hondaautomotiveparts.com
Or your local dealer.
How about the junkyard?
Old Jun 4, 2004 | 07:07 PM
pburke23's Avatar
Default Re: Help Quick Please! (EL Vap133)
what about getting the rest of the bolt out of the bottom part? theres only a little bit exposed for me to work with, its brokin inside for the most part..
Old Jun 4, 2004 | 07:10 PM
Soccerking3000's Avatar
you are going towant to buy a tap and drill it out and retap the hole, i also found out if you take a bit that is the exact size of the hole w/o the threads and drill it out, you can then take another bolt and torque it in and it will make the small bits of metal still in the threads come out i have don it before and it works well as long as you dont break that bolt in there too
Old Jun 4, 2004 | 07:13 PM
pburke23's Avatar
Default Re: Help Quick Please! (Soccerking3000)
http://www.hondaautomotivepart...DX%29
from this page, which are the ones i need? I need the bottom bolt, and the sliding pin that it fits into...
Old Jun 5, 2004 | 09:14 AM
pburke23's Avatar
bump...just need to make sure i order the right ones..
DCRB
13
Mar 23, 2010 09:47 AM
Mr.Speed
Mar 13, 2008 04:09 AM
Ragecloak
Feb 25, 2005 07:54 AM
pburke23
Jun 4, 2004 10:00 PM
civicracer1993
Apr 18, 2002 07:50 PM
