What kind of damage could excessive oil cause?
Old Jun 4, 2004 | 05:04 PM
is3oo's Avatar
Default What kind of damage could excessive oil cause?
My R had problems starting up yesterday. It would crank, but I couldn't get it to start for a while. I checked the oil level and it was about 1 quart high. Now I was wondering if this is what caused my car not to start? And what kind of damage could excessive oil result in? Thanks.
Old Jun 4, 2004 | 05:37 PM
Utilitarian's Avatar
Default Re: What kind of damage could excessive oil cause? (rowdy type R)
First of all, do you change your own oil?
Old Jun 4, 2004 | 05:41 PM
Dirt's Avatar
Oil foaming which can increase oil pressure causing failure to seals/gaskets.
Old Jun 4, 2004 | 06:43 PM
is3oo's Avatar
Default Re: What kind of damage could excessive oil cause? (Utilitarian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Utilitarian &raquo;</TD></TR><TR><TD CLASS="quote">First of all, do you change your own oil?</TD></TR></TABLE>
Sometimes I do. Last time I didn't.
Old Jun 4, 2004 | 06:44 PM
is3oo's Avatar
Default Re: What kind of damage could excessive oil cause? (BrewCityR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrewCityR &raquo;</TD></TR><TR><TD CLASS="quote">Oil foaming which can increase oil pressure causing failure to seals/gaskets.</TD></TR></TABLE>
So do you think this caused my car to act this way?
Old Jun 5, 2004 | 09:57 AM
Big Phat R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rowdy type R &raquo;</TD></TR><TR><TD CLASS="quote">I checked the oil level and it was about 1 quart high. Now I was wondering if this is what caused my car not to start? And what kind of damage could excessive oil result in? Thanks.</TD></TR></TABLE>
Please clarify the above.
Old Jun 5, 2004 | 09:58 AM
HUBB's Avatar
i did the same thing when i changed my oil last filling it up a quart or so too much and heard the same thing about burning rings and such...i just backed up the drain plug a few threads until it was leaking a small amount and i used an empty quart to judge the amount i was draining... worked perfect...
Old Jun 5, 2004 | 10:00 AM
HUBB's Avatar
Default Re: What kind of damage could excessive oil cause? (Big Phat R)
he means oil was above the upper line on the dipstick...or at least that was the case for me
Old Jun 5, 2004 | 10:07 AM
98cwitr's Avatar
Default Re: What kind of damage could excessive oil cause? (HUBB)
good god...how do you over fill by a whole quart???
Old Jun 5, 2004 | 10:15 AM
HUBB's Avatar
Default Re: What kind of damage could excessive oil cause? (98cwitr)
i got distracted and thought i was on my 4th quart when i was really on my 5th
Old Jun 5, 2004 | 10:39 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98cwitr &raquo;</TD></TR><TR><TD CLASS="quote">good god...how do you over fill by a whole quart???</TD></TR></TABLE>I dunno about just ONE quart too high but I've driven my '93 CX winter beater with DOUBLE the oil capacity for a day, it was running... um, well, SLUGGISH!
I had pulled the D15B out of my Hybrid the year before then recently dropped it into my new winter beater that had no motor. I assumed my friend drained the motor oil, but, he never did, so when we installed it, I dumped in the recommended amount of motor oil. When we fired the engine up there were no problems but it was prrrrrrrrrretty slow. Mind you, it didnt feel too off since it was a 75 hp CX motor, but after a day of it blowing some smoke and it feeling really wheeeeezy, I thought of the problem, checked it and drained out all of the gllons of oil, holy smokes was there a lot of oil in that little 1.5 liter D series motor!
Old Jun 5, 2004 | 10:44 AM
HUBB's Avatar
Default Re: What kind of damage could excessive oil cause? (owen_the_soyboy)
damn 2 quarts! thats nuts...suprised it ran
Old Jun 5, 2004 | 10:50 AM
py1188's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HUBB &raquo;</TD></TR><TR><TD CLASS="quote">damn 2 quarts! thats nuts...suprised it ran </TD></TR></TABLE>
Thats more like 4 qts over, being double the reommended level, not double as in two quarts over.
Old Jun 5, 2004 | 10:59 AM
HUBB's Avatar
Default Re: What kind of damage could excessive oil cause? (py1188)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py1188 &raquo;</TD></TR><TR><TD CLASS="quote">Thats more like 4 qts over, being double the reommended level, not double as in two quarts over.</TD></TR></TABLE>
ur right
Old Jun 6, 2004 | 03:48 AM
is3oo's Avatar
I forgot all about this thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">
Please clarify the above.</TD></TR></TABLE>
The oil level is about a half-inch above the second dot on the stick. I assumed it's about a quart. I haven't driven my car since that incident. I was just going to get an oil change on Monday. So how much driving would it take before it causes any serious damage? I must of drove like that for about a week. I'm trying to figure out if my oil level caused my car not to start or if it's something else causing it.
Old Jun 6, 2004 | 06:49 AM
jond's Avatar
I knew a guy in college who put too much oil in his car, and it blew his headgasket, which basically destroyed the entire motor.
ahron
Sep 9, 2007 06:59 PM
Steve26
Jul 29, 2004 05:09 PM
See Are X
Mar 5, 2004 07:13 PM
d9h
Jan 31, 2004 11:58 PM
Rhetoric
Aug 6, 2003 12:59 AM
