steering rack adjustment?
Old Jun 4, 2004 | 02:07 PM
4genblack's Avatar
Default steering rack adjustment?
I have a lot of play in my rack. Clunking noises, when I hit bumps, and play side to side when it's up on the hoist. I can hear the clunking noise coming from the rack itself, when the car is in the air and i wiggle the wheel. It's coming from inside the rack. My Q is, is there any adjument bolts or nuts that I can use to tighten up the steering. I tried searching and only found rack removal tips.
Thanks in advance...
Old Jun 4, 2004 | 02:22 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: steering rack adjustment? (4genblack)
http://www.binghamtonlife.com/...4.jpg
Old Jun 4, 2004 | 02:29 PM
4genblack's Avatar
Default Re: steering rack adjustment? (88DXCRX)
right on man thanks. Now I can drive without the fear or losing a wheel. Damn 40mm nuts, pipe wrench should do it.
Old Jun 4, 2004 | 02:36 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
i think i need to save this thread.....i might have to do the same thing....
i have replaced my tie rods in and out...axles both....shocks and springs...upper arm with upper joint and lower balljoint........and its still doing it...i acrtually replaced my rack and pinion 8 months ago, does that mean that the shop f#$%$ me over by not adjusting it correctly???...unless person before me hit a curb and bent something right? let me know what you guys think. Thank you......
Old Jun 4, 2004 | 03:37 PM
dgonzals's Avatar
ttt
Old Jun 4, 2004 | 05:11 PM
UK CIVIC B16A2's Avatar
On that link is the bottom drawing of relevance to the rest or is it the next topic in whatever book that is? I dont remember seeing any 40mm nuts under there, tho i know some racks (not nessesatily hondas) can be adjusted. That link seems to me to only demonstrate a way to adjust the friction in the rack. Im hoping and praying that the freeplay is ajustable but i think it might be just one of those too good to be true things. Can anyone else with any quality knoledge of these racks verify this please? (no offence 88DXCRX )
Old Jun 4, 2004 | 05:20 PM
4genblack's Avatar
Default Re: steering rack adjustment? (UK CIVIC B16A2)
I'm gonna try this tomorrow. I will let you guys know how it went. I got a parts car for 50 bucks, so at least I can just swap the rack if it doesn't work. Do you guys know if a 91 si rack will fit a 89 si.
Old Jun 4, 2004 | 07:01 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UK CIVIC B16A2 &raquo;</TD></TR><TR><TD CLASS="quote">On that link is the bottom drawing of relevance to the rest or is it the next topic in whatever book that is? I dont remember seeing any 40mm nuts under there, tho i know some racks (not nessesatily hondas) can be adjusted. That link seems to me to only demonstrate a way to adjust the friction in the rack. Im hoping and praying that the freeplay is ajustable but i think it might be just one of those too good to be true things. Can anyone else with any quality knoledge of these racks verify this please? (no offence 88DXCRX )</TD></TR></TABLE>
The nut is below the pinion rod, on the bottom side of the rack. It's directly below where the steering knuckle attaches to the rack. But I agree with you. It only adjusts friction on the rack. It won't do anything for free play. CRX /EF racks are not adjustable for free play. If you have that much play in the rack, time for a new one. Sorry, but that's the only solution. Ask me how Iknow this.
But you can try it, and see, let me know if it hepls, any.
Old Jun 4, 2004 | 10:37 PM
Tyson's Avatar
Default Re: steering rack adjustment? (4crx4me)
i would first replace the steering rack bushing first. its a small plastic thingy on the passenger side. gotta take off the inner tie rod first. but you can test it by putting the steering to full lock and jiggling it, actually pushing it really hard. it shouldnt move.
but then again, if your steering rack boots were torn and the steering rack was all chewed up, i dont think any amount of adjustment can save it, just needs replacing.
Old Jun 4, 2004 | 10:40 PM
dgonzals's Avatar
i need someone local to help me check mine out....and i dont like reading books....
Old Jun 4, 2004 | 10:43 PM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
ttt
Old Jun 6, 2004 | 01:52 PM
4genblack's Avatar
Default Re: steering rack adjustment? (Tyson)
Ya it didn't work out. Help a bit I think, but hard to notice. I just pulled the rack out of the parts car and I'm gonna replace mine ow well. Thanks for the help anyways.
White_EG1
23
Apr 12, 2016 08:34 PM
soner
Aug 26, 2008 04:53 PM
PatrickGSR94
Jun 18, 2007 12:32 PM
na4now
Feb 7, 2006 10:46 AM
PhatHardy
17
Jan 21, 2003 01:37 PM
