does the phantom grip lsd werk? and wheres the cheapest place to get 1???
Old Jun 4, 2004 | 09:24 AM
teggylude99's Avatar
Default does the phantom grip lsd werk? and wheres the cheapest place to get 1???
ive gotta 99 integra with a h22 in it ...and have i had hell with axels ! well after about 6 months driving a human vibrator it wore out my diff...so if u know where i can get a good deal on a lsd or chap h22 tranny let me know,
thanx.....
Old Jun 4, 2004 | 09:41 AM
Kal's Avatar
Kal
Default Re: does the phantom grip lsd werk? and wheres the cheapest place to get 1??? (teggylude99)
phantom grip isn't a true LSD, you should just spend it on a quaife unit. Check vendor's corner for a quaife LSD.
Old Jun 4, 2004 | 09:47 AM
bad-monkey's Avatar
the Random Grip is a POS. it'll work for a few months then crap out.
save money and time and get yourself a bulletproof quaife, unless you're good at and like tearing apart trannies.
Old Jun 4, 2004 | 10:16 AM
H duce duce's Avatar
there was a big thread on the phantom grip, it is apparently gone now, but it basically said that if u get the right spring with it, and have it installed correctly, it is fine, and if i recall correctly there were people claiming to have used them on 450+ whp drag cars with no problem, but i couldnt find the thread soo......
Old Jun 4, 2004 | 10:22 AM
bad-monkey's Avatar
Default Re: does the phantom grip lsd werk? and wheres the cheapest place to get 1??? (H duce duce)
the right spring = custom modifications to an already crappy unit. sounds like a band-aid fix to me.
i have never met a Phantom grip owner who has had the unit for more than a year who recommends the product. the typical story is: it worked ok at first, and it stopped after X amount of time. i'm not sure how much longer a stiffer spring will last in the unit, and if the extra force exerted by the stiffer spring is good for your spider gears.
at any rate the PG is a big question mark, good springs or not. With quaifes only costing a few hundred more, and a rock solid reputation as the best gear-type LSD on the market, i don't see the point in installing the PG into a tranny (which is a total pain in the ***) if it won't work forever. Especially since tranny work is expensive for those who cannot DIY.
Old Jun 4, 2004 | 10:31 AM
Default Re: does the phantom grip lsd werk? and wheres the cheapest place to get 1??? (bad-monkey)
so u have no expierience with one, but u called it a POS, interesting
thats exactly what happened on that old thread, the first few posts were people saying what pieces of **** they HEARD they were, then a bunch of people started posting that they had no problems with it, the said to call the lady at phantom grip, and tell her what your specific application is
i dont have expierience with one either, but thats just the info i got for them, and thats what this guy is asking
Old Jun 4, 2004 | 12:18 PM
bad-monkey's Avatar
i don't have direct experience with one, but when 9 out of 10 users tell me that it's failed within a year, i don't think i need direct experience with one to know that it's a piece. Also, when i reflect upon the design of the unit, and start thinking about the potential ramifications of design (flaws) it doesn't take a genius to imagine that it's designed pretty poorly. heap on top of that fact that it's probably made poorly and you've got a winner.
i've got a quaife. it works. seamlessly. no complaints and not all that expensive either, as far as LSD's go. the only other alternative i'd consider is a cusco or a kaaz.
Old Jun 4, 2004 | 12:37 PM
Kal's Avatar
Kal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">i don't have direct experience with one, but when 9 out of 10 users tell me that it's failed within a year, i don't think i need direct experience with one to know that it's a piece. Also, when i reflect upon the design of the unit, and start thinking about the potential ramifications of design (flaws) it doesn't take a genius to imagine that it's designed pretty poorly. heap on top of that fact that it's probably made poorly and you've got a winner.
i've got a quaife. it works. seamlessly. no complaints and not all that expensive either, as far as LSD's go. the only other alternative i'd consider is a cusco or a kaaz.</TD></TR></TABLE>
yep. the phantom grip just looks like two pieces of metal put together opposed to a torsen lsd or a clutch type lsd.
Knightzero7
Transmission & Drivetrain
Apr 10, 2014 02:39 PM
Broken Devil
Jul 1, 2005 06:33 PM
-Bionic-
Aug 7, 2003 06:39 AM
dominate9
Jun 12, 2003 12:37 PM
h22dc2
Apr 13, 2002 08:44 AM
