Piston removal
Old Jun 4, 2004 | 06:53 AM
deSigi's Avatar
Default Piston removal
I'm going to send my b18c1 head out to get rebuilt (guides, seals) and while it was out, I was planning on changing my rings. I don't want to remove the block from the engine bay, so I'll do it from under the car. How difficult is it to knock the piston out, if the crank is still installed? I wouldn't want to damage the oil jets.
Also, when re-installing the rods, they don't specify this in the Helms manual, but I'm assuming oil must be applied to the rod bearings before reassembly?
Old Jun 4, 2004 | 07:10 AM
devnull's Avatar
Pistons only come out through the top. Once hte head is removed you undo the rod caps and push the piston up through the top. Use asoft wooden hammer if you need some extra reach.
Old Jun 4, 2004 | 07:21 AM
deSigi's Avatar
Default Re: (qi_doy)
I know that, I just wanted to know if it's too difficult to do it with the crank still in. It would go a lot quicker if I could leave the crank in there.
Old Jun 4, 2004 | 09:18 AM
mmuller's Avatar
Mad Scientist
Default Re: (e-kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e-kay &raquo;</TD></TR><TR><TD CLASS="quote">I know that, I just wanted to know if it's too difficult to do it with the crank still in. It would go a lot quicker if I could leave the crank in there.</TD></TR></TABLE>
no its not difficult to take them out.....whats going to be difficult is honing the cylinders and not getting **** all over the crank...
Old Jun 4, 2004 | 09:29 AM
deSigi's Avatar
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
no its not difficult to take them out.....whats going to be difficult is honing the cylinders and not getting **** all over the crank...</TD></TR></TABLE>
You're right.....damn.....to hell with it, I'll just get it done. I'm short on time anyways.
Thanks for the info.
integraRS-T
Nov 22, 2007 11:02 AM
eg_gsr11
Mar 5, 2006 04:27 PM
caspers_hatch
Mar 20, 2005 07:52 PM
sodacan33
Jun 10, 2004 07:10 AM
ScrapinSi
Jul 18, 2002 03:09 PM
