transmission swap: can i swap without removing the motor?
Old Jun 4, 2004 | 01:01 AM
Sinner's Avatar
Default transmission swap: can i swap without removing the motor?
I've done a few swap, but they have all included both motor and tranny. Now I just blew my tranny out and want to replace it. I dont see the tranny coming out the top side, but maybe pull off the rear motor mount and the tranny motor mounts. Then pull the tranny from the bottom.
Anyone have any expierence trying this? or is this just one of those 4:00 am ideas that should go away?
Nick
Old Jun 4, 2004 | 05:28 AM
EE_Chris's Avatar
Default Re: transmission swap: can i swap without removing the motor? (Sinner)
Yes you can drop it out underneath the car.....I'm not even sure you can pull the tranny alone from the top, that'd be hella hard IMO. You will need to support the engine as 3 of the mounts are on the tranny and will obviously have to come off.
Old Jun 4, 2004 | 06:42 PM
93Civac's Avatar
Yeap, remember to support the motor and you will want to drop it out the bottom.
Old Jun 4, 2004 | 08:20 PM
senpai's Avatar
Done it like 10 times now ... wish I had a car lift
Old Jun 4, 2004 | 08:31 PM
RABHonda's Avatar
Default Re: transmission swap: can i swap without removing the motor? (maztur)
dont support the engine at first and let it hang sideways, this will help you pull the tranny off. actually, when i think of it, you dont need to support the engine at all...til you are ready to put the new tranny in.
Old Jun 4, 2004 | 08:46 PM
3rdGteg's Avatar
Default Re: transmission swap: can i swap without removing the motor? (RABHonda)
I think it'll be a good idea to support the engine after removing the tranny since it'll be just hanging on to only the one driver's side mount especially if you're planning to reinstall everything at a later time. You can use a piece of 4x4 over the jack so you won't mess up the bottom of the engine. Good Luck
Old Jun 13, 2004 | 10:20 PM
Sinner's Avatar
update: it worked and it saved a hell of alot of time!
jdmeg21
11
Aug 21, 2009 03:34 AM
a1320honda
Sep 23, 2007 09:36 PM
redex94
May 9, 2003 07:07 PM
Shaun
Apr 8, 2003 07:49 PM
leprechan117
11
Mar 10, 2003 04:03 PM
