type r engine swap
Old Jun 3, 2004 | 11:50 PM
dennislor's Avatar
Default type r engine swap
does anyone know 98 type r engine with its engine harness plug in 95 civic cx car? i have type r engine harness and complete swap but not sure if it will fit my 95 civic cx , help please
ps i have 98 type r under dash harness, will it fit without it?
Old Jun 4, 2004 | 12:02 AM
2k.civic.si's Avatar
Default Re: type r engine swap (dennislor)
when u swap motors swap the wire harness....and the stock ecu in the car wont work....hopefully your swap came with an ecu...otherwise find a p28 and chip it....
Old Jun 4, 2004 | 01:38 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennislor &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know 98 type r engine with its engine harness plug in 95 civic cx car? i have type r engine harness and complete swap but not sure if it will fit my 95 civic cx , help please
ps i have 98 type r under dash harness, will it fit without it? </TD></TR></TABLE>
if you have a US ITR engine, YES, the engine harness will be compatible with your CX. You don't need the underdash harness at all.
If you have a JDM ITR engine harness, NO, it will not work. You're best off to try and locate a US 96-01 integra VTEC engine harness, if you have a JDM ITR engine, for it to work in your CX.
Old Jun 4, 2004 | 08:23 AM
dennislor's Avatar
Default Re: type r engine swap (Katman)
i have everything usdm, do you mean it will direct plug in my stock under dash wires and plugs? that was my question
Old Jun 5, 2004 | 04:51 AM
Boosthead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennislor &raquo;</TD></TR><TR><TD CLASS="quote">i have everything usdm, do you mean it will direct plug in my stock under dash wires and plugs? that was my question</TD></TR></TABLE>
As Katman was saying, the usdm ITR harness will plug into all of the plugs in the engine bay. Simply unplug the CX harness, remove engine, install ITR engine, and plug in the ITR harness. The ITR under dash harness is not needed. This truly is plug n' play
rlacasse1
15
May 28, 2018 05:03 PM
93slmdcvcsi
Jul 16, 2011 06:40 PM
NAlover
Nov 22, 2009 06:53 PM
