Stock 240cc injectors or RC 290cc injectors with Toda A's in a CTR motor??
you might want to use 310's to be safe.
you can always make the adjustments.
better than being to small.
i have a set for sale. saturated practically brand new.
p'm if interested.
$200 shipped.
p'm if interested.
$200 shipped.
stock pump is fine. all you need is stock injectors. 240cc injectors can support over 200 whp, doubtful you'll go over that.
It all depends on your set-up I was running 290's and they were reaching there max duty cycle at like 7000 rpms. I would go with 310's.
I am running stock ctr motor with toda A cams and cam gears, Toda Header, Spoon sports cat back, 190lph pump, Intake AEM FPR and hondata.
i dont think you will take full advantage of a hondata yet, but ecu,stock pump. stock injectors.. get a fuel pressure regulator, gauge, timing light and call it day.. your not going anywhere by bogging down your motor with a ton of extra fuel it doesnt even need. keep it simple fella. dont over do it!
I have a fpr an 190lph pump. I want to squeeze a little mor hp out of the motor. With the toda a's and hondat I should see a nice gain or I hope to.
