Spark Problems
Old Jun 3, 2004 | 06:16 PM
Origin's Avatar
Default Spark Problems
still having spark problems. car is a 88 crx hf with an integra 93 integra xsi engine in it. car has been converted to obd1. i know the ecu is good, the battery is charged. i have replaced the ignitor, coil, rotor, and cap. i know i have power getting to the distributor. im not sure how strong the signal is though. by the way, the battery has been relocated to the trunk. im 99.9% that i have all the grounds needed (valve cover, tranny, wire harness grounded to thermo housing, and i have a separate ground from the thermo housing going to the body just for extra grounding.
when i try to crank it though it seems to be alot stronger sounding though. inface while i have one of the spark plugs out of the cylinder as i crank it i can see a spray of gasoline coming out (just one spray) and then when i turn the key back out of accessory it actually seems like it turns the other way, such as a bit a tension was let off of the crank. if i could only get spark im positive it would crank. im pretty sure this problem is something stupid so if anyone has any idea just let me know.
Old Jun 5, 2004 | 02:03 PM
Origin's Avatar
Default Re: Spark Problems (Origin)
potatointegra01
Apr 1, 2015 09:32 PM
yzhang
Jun 21, 2009 11:13 AM
teal91
Dec 5, 2008 04:45 PM
bsshep01
Jun 7, 2004 10:33 AM
Origin
Jun 5, 2004 02:01 PM
