kyb agx problem
I currently bought kyb agx's about 5 months ago from KYB Warehouse on EBAY. I was getting ready to get them installed I only opened one because I wanted to check em out. I went and opened all of them and noticed I dont have ANY adjusting ***** anywhere in the box. Has anyone else ran into this problem where the person didnt send the adjusting *****? KYB Warehouse is giving me a hassle about returning them also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">what application?on most Honda applications,the top end of the strut rod contains the adjustment screw.
Chris</TD></TR></TABLE>
this is true, i thought i got jipped too, but all 4 of mine have a little dial on the very top end of the poston rod, you use the little screwdrivers to turn them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon92hatch »</TD></TR><TR><TD CLASS="quote">wrong.......they come with adjustments on the top....all 4</TD></TR></TABLE>
correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Drag »</TD></TR><TR><TD CLASS="quote">just look at the strut at the end where it is "THREADED" you should see a dial there.. thats where you make the adjustment.
Look at NUMBER 7:
exactly...enough said i'm done
correct
Look at NUMBER 7:
some agxs do have a **** on the bottom for adjusting. My wifes 97 civic ex 4 door had them like that and my buddys 97 teg has them like this also. The 97 civics had a 8 way adj. on the rear and my friends with the teg has a 4 way adj ****.
It does have a lil dial that has those numbers at POINT 7. It should be on the very top of that. You should be able to adjust it with the tiny flat head that they included in the package.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol »</TD></TR><TR><TD CLASS="quote">Oh....I thought I was supposed to have one of those dials that have the numbers 1-5 or 1-6 and ya just turn it...</TD></TR></TABLE>
From: South LA...107th and fig to be exact...for the foo
mines came with little screw drivers to adjust them...there is a little slot on the top, each setting has a different color...red, white, green, and yellow
i have a set on my eg they only have four settings wich i mentioned 1-4
i have tha AGX'z -- there should be a **** on tha top & **** on tha sides .. depending if yoru lookin @ tha shocks or tha struts.
shocks/struts have tha adjustment screw/**** in diff places.
