which block is better to use b18a or b18b
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96gsr4dr »</TD></TR><TR><TD CLASS="quote">same block. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tray3rd »</TD></TR><TR><TD CLASS="quote">can i use the b18a block to build an ls vtec and put in a 94 civic dx. i have a 96 gsr head will it on that block
with the proper ls/vtec fittings and what not yes you should have no problem. hopefully your engine builder in FL has done it before.
</TD></TR></TABLE>with the proper ls/vtec fittings and what not yes you should have no problem. hopefully your engine builder in FL has done it before.
I'd rather use a b18a due to the fact that is has a PCV breather built in. Otherwise you have to drill or use a endyn breather system if you want a PCV system on the motor
There are a couple of reasons to go B18B. One is because it is newer. Bu this doesn't matter if you plan to build. Another reason to go B18B is if you live in California. If you go B18A, you will have to go with the inferior B18A head and intake manifold for smog reasons.
wellt he difference I noticed
is that the B18a comes with a knock sensor
and a B18b doesn't as it is from obd1 and up
that is what I noticed for 90-91 and 92-93 blocks
and wow did know about this???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 »</TD></TR><TR><TD CLASS="quote">I'd rather use a b18a due to the fact that is has a PCV breather built in. Otherwise you have to drill or use a endyn breather system if you want a PCV system on the motor</TD></TR></TABLE>
and I am goign z10 breather kit
