Coilover question?......Help!
Hello, I have a set og BOMZ coilovers .
They did not come with instructions, I have four springs, four threaded housings ,
the lock nuts etc... Now comes the part I do not understand.
There is a bag that has a whole bunch of O-Rings in it? also it has four metal o-rings ( seats) ......can someone help me out here?
Thanks, Bob
Thanks, Bob
the rubber o-rings go on the shock and then the threaded shaft goes over the o-rings and shock. as for the seats, if they are the ones i am thinking about they go on top part of the spring, then the top hat goes on top of the seat. hope this helps, im not to good at explaining things
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShAAdiiiNG »</TD></TR><TR><TD CLASS="quote">the rubber o-rings go on the shock and then the threaded shaft goes over the o-rings and shock. as for the seats, if they are the ones i am thinking about they go on top part of the spring, then the top hat goes on top of the seat. hope this helps, im not to good at explaining things
Agreed on the first part, not too sure about the second part.
</TD></TR></TABLE>Agreed on the first part, not too sure about the second part.
