Weird, Can't put car into gear, help
Old Jun 3, 2004 | 04:40 AM
40oztoFreedom's Avatar
Default Weird, Can't put car into gear, help
I was driving down the road in my 94 gsr, just driving normally, not ragging on it, and right after i pulled up to a light and stopped i couldn't put the car back into gear. It was almost as if i had no clutch or something. Now when i turned the car off i could go thru the gears all i wanted but when it was on it just wouldnt go into gear. Also when this happened i noticed a difference in clutch pedal feel, like it got a little bit softer. Anyone had this happen to them or know what this could be? thanks
Old Jun 3, 2004 | 07:37 AM
spoonfed95's Avatar
Default Re: Weird, Can't put car into gear, help (40oztoFreedom)
Check the Clutch master cylinder, slave Cylinder, and lines for leaks. Easy fix if leaking, sounds like this will be your problem.
Old Jun 3, 2004 | 11:11 AM
JDMG2i's Avatar
see if you need tranny fluid also start your car in gear and see if it will drive so you can find out if your tranny is working also see if you can start your car with no clutch if you can its your clutch
Old Jun 3, 2004 | 11:40 AM
IntEGNYC's Avatar
Default Re: Weird, Can't put car into gear, help (JDMG2i)
check the clutch fluid levels. If you are having problems and cant rush to the garage, carry a bottle of DOT3 in the car incase you run low.
Helps if you learn how to bleed the clutch as well, just incase.
jlowellintegra
Jun 18, 2011 11:43 PM
Dav94Lx
Feb 2, 2008 07:53 AM
scrEaMO Kyle
Nov 3, 2005 11:49 AM
Luchini
Oct 16, 2005 11:15 AM
hybrider
18
May 9, 2002 08:08 PM
