B18B timing advance question
Old Jun 2, 2004 | 10:00 PM
treimche's Avatar
Default B18B timing advance question
Tried to search but got like 5 results that didn't help at all. I've got a B18B in my hatchback and I'm wondering how much timing advance I can run and make a little more power. I don't have access to a dyno right now, otherwise I'd just get on and do it. I've just got an intake, header, and 2-1/4 exhaust. Maybe this is a stupid question, but would race gas and more timing help out at all? I'm new to the all motor thing, I'm a turbo guy so I know what's good for my DSM, but not for the n/a motor. Thanks.
Old Jun 2, 2004 | 10:01 PM
mmuller's Avatar
Mad Scientist
Default Re: B18B timing advance question (treimche)
18 btdc
Old Jun 2, 2004 | 10:55 PM
hYbRid_Eg6's Avatar
well the most power i got was at 16 btdc, well for the race gas, u dont really need it because the compression ratio of the ls is so low, 92 octance will do just fine, unless u like ur exhaust to smell really good
Old Jun 2, 2004 | 11:48 PM
Joseph Davis's Avatar
Go 2-3 degrees advanced from stock, common practice.
Racegas isn't good for an engine that isn't meant for it... atomises poorly and burns so slowly you'd throw still burning AF out your exhaust valves, effectively running you lean and overheating the combustion chamber, leading into your engine shitting itself in short order. If you don't have a turbo car with your boost turned up to be at the track, or running high compression NA, you don't want the stuff. You always make the best power running the lowest octane gas you can get away with.
Old Jun 3, 2004 | 09:33 PM
treimche's Avatar
Alright thanks for the replies. Sounds like you guys know what you're talking about.
Old Sep 26, 2008 | 02:03 PM
. r i c h 9 9 0's Avatar
Default Re: (treimche)
Sorry to dig up an old thread, but i didnt want to post a new one and be told to search...
I have a stock b18b in my 4door civic...
Timing is at 16deg at the moment and i have i-h-e...
Question is, will i be ok running 19 or even 20 deg timing?
We have 95 gas here in south africa, but i've been told its the equivalent of 91 in the states...
Is 20 deg too advanced, will i get detonation?
Thanks in advance
Old Sep 27, 2008 | 02:37 AM
Default Re: (. r i c h 9 9 0)
No one?
Old Sep 27, 2008 | 09:02 AM
LastGenEK's Avatar
I think 20 is OK But you might over heat at idel LOL hahaha
Turn it to 18deg like they ^ said sounds good to me though
Old Nov 5, 2008 | 11:12 PM
jdmer329's Avatar
no just 18 will be good. thats what my timing is in my b18b. and it will be safer running a colder spark plug. stock is 5 , get 6 to help it run cooler when ur timing is advance and running 91.
bOOsTiNSoHcVtEc
Jul 23, 2004 01:23 PM
ThEOutSidEr
Apr 18, 2004 09:43 AM
KooK
Apr 27, 2002 08:51 AM
fo-do
Mar 8, 2002 03:19 PM
