d15b2 Oil Pan on d16z6
100% sure D15's and D16A6 are interchageable.
So I'd say 98% sure the D15's and Z6 are the same.
To be 100% sure, call a honda dealer and get both part numbers, if they match, you have your answer. Actually, I can get the P/N for D15. I have a CRX parts manual in my archives somewhere
HTH
HTH
It might not. I forget exactly what a D15B2 is. But if it is from either a STD or HF, you will have problems. It seems that Honda decided to make a different oilpan for motors equipped with close-coupled cats. If you try to use a downpipe from a car with a non-close-coupled cat, it will interfere with the oilpan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurinto »</TD></TR><TR><TD CLASS="quote">its off of the dx crx, does close-coupled cat mean the cat is connected to the downpipe? cause the crx dx does not have this.</TD></TR></TABLE>
ONLY the HF has the cat right up below the ex mani.
Si and DX do NOT.
The D15B2 and D16A6 use the exact same oil pan. I am 100% sure of this.
The part number is. 11200-PM3-010 or 11200-PM3-020.
The '88's use a different pan. Just cross ref the # with a dealer.
Si and DX do NOT.
If he is using the stock Z6 header the downpipe will hit the D15/D16 oil pan, he may be able to dent/smash it but I have heard of people cracking/damageing the pan doing this
it will not work
i had a B1 on my Z6 once
and i had to ghetto rigg it
i had to re drill the oil pump bolt holes, and still leaked with hondabong
the outer design is the same, but the bolt pattern isnt
u can make it work if u HAD TO, but it will leak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurinto »</TD></TR><TR><TD CLASS="quote">Will this work? I have someone interested in the d15 oil pan I have for sale to go on their d16z6. I want to be certain it will work for them if I sell it. Thanks</TD></TR></TABLE>
Wont work d15b2 Pan is too shallow and the pickup hits....
Hrm I put my old d15b2's oil pan from my 88 STD hatch on my ZC because it's pan was dented all over. I had no fitment issues whatsoever, with both the close-cat downpipe AND with a chikara header for a EG/EK, so I'm interested in hearing people that have REAL experience, not "I heard" or "I think", someone else done this? Mine worked just fine and has now for 6 years (I probably have the longest running ZC in the NW).
I told you guys how to tell if it'll work.
I gave you the part number at the begining of the B2/ A6 oil pan. Call a honda dealer and get the part number for the oil pan for the engine you want to swap to/ or from. If the numbers match. It's a direct swap. (Yes I know, no USDM ZC)
Don't waste your time asking for opinions. Find out by doing.
In my experience it's much LESS aggravating than asking anyone here.
DelSolSi93
21
Sep 20, 2004 10:34 AM
