d16 vtec in ef models. how are you guys running vtec
Old Jun 2, 2004 | 01:27 PM
kyosoeg6's Avatar
Default d16 vtec in ef models. how are you guys running vtec
i think im going to purchase another crx and id want to do a minime for one of my first mods. my prob is i have never ran d16 vtec in an ef. a few locals are doing it but they have a window switch and i reallydont like that idea. another local has a reprogrammed ls computer with an apex i to activate vtec.
i also thought of using a pr3 or pw0 but i thought that might be too much fuel for my pretty much stock d16
Old Jun 2, 2004 | 02:22 PM
phatrick2332's Avatar
Get a chipped ecu, and run Turboedit, its now 1 wire vtec able.
Trance minister's Avatar
Default Re: d16 vtec in ef models. how are you guys running vtec (kyosoeg6)
I don't have it running yet but to activate my Vtec I just got an MSD RPM switch. Also if you have one of those huge *** tach's with the adjustable RPM shiftlight, you can wire the vtec into the shiftlight and set the RPM to whatever you need/want.
Old Jun 2, 2004 | 02:33 PM
I3ackfire's Avatar
Default Re: d16 vtec in ef models. how are you guys running vtec (Trance minister)
One of the most common are probably using the VAFC, and you can find them fairly cheap now that Version 2 has came out.
Old Jun 2, 2004 | 02:38 PM
kyosoeg6's Avatar
Default Re: d16 vtec in ef models. how are you guys running vtec (I3ackfire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ackfire &raquo;</TD></TR><TR><TD CLASS="quote">One of the most common are probably using the VAFC, and you can find them fairly cheap now that Version 2 has came out.</TD></TR></TABLE>
this is what i was leaning more towards. i already have one so i think that would be my best bet. anyother suggestions
Old Jun 2, 2004 | 02:56 PM
Bserieskllr's Avatar
im running a pr3 for mine it runs good and not to rich but i also have a cam and some bolt ons it may run a little rich on stock mini-me.
Old Jun 2, 2004 | 03:33 PM
kyosoeg6's Avatar
Default Re: (Bserieskllr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserieskllr &raquo;</TD></TR><TR><TD CLASS="quote">im running a pr3 for mine it runs good and not to rich but i also have a cam and some bolt ons it may run a little rich on stock mini-me.</TD></TR></TABLE>
that sounds good. if and when i do get this crx i may just wait and do the head with a zc piston block and the boltons with a skunkmani. im sure with a fpr id be good to lean it out a bit.
thanks for the pointers everybody
Old Jun 2, 2004 | 04:53 PM
yea i'd say go for the p29's and maybe even a cam.....this motor really surprised me, the first time i ran the car i only ran a 16.1 then after tuning i ran a 14.5 i know with some better traction she will be good for 13's. good luck.
Old Jun 2, 2004 | 05:12 PM
allicedout's Avatar
I've got a switch hooked up to the throttle linkage in the engine. its mounted so that the throttle spindle hits it at WOT. so basically whenever i go full throttle i got VTEC. It works great.
Old Jun 2, 2004 | 05:16 PM
kyosoeg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allicedout &raquo;</TD></TR><TR><TD CLASS="quote">I've got a switch hooked up to the throttle linkage in the engine. its mounted so that the throttle spindle hits it at WOT. so basically whenever i go full throttle i got VTEC. It works great. </TD></TR></TABLE>
dam thats pretty cool. ive never heard of it. id like to go with something that lets me control my engine though not just activating vtec. like an ecu actually has function with fuel and ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserieskllr &raquo;</TD></TR><TR><TD CLASS="quote">yea i'd say go for the p29's and maybe even a cam.....this motor really surprised me, the first time i ran the car i only ran a 16.1 then after tuning i ran a 14.5 i know with some better traction she will be good for 13's. good luck.</TD></TR></TABLE>
ya the p29 or the pm7. i have them both. i also have a bullfrog cam but ive been thinking of buying a skunk2 stg 1 that is for sale here on the forum just to try it out. or going with a bullfrog head or a complete package from wil at exospeed. im just keeping my options open basically.
Old Jun 2, 2004 | 05:23 PM
KOOL-AID's Avatar
Default Re: (kyosoeg6)
why not just convert to obd-1
Old Jun 2, 2004 | 05:25 PM
kamikazeCRX's Avatar
I activate the VTEC in my car with the MSD activated switch....i would suggest going another route.
I have the fuel pressure regulated fine for normal driving, but as soon as it hits VTEC, it gets a little lean. Of course, if i put it up for VTEC, it would probably run rich when not on VTEC
Old Jun 2, 2004 | 05:26 PM
Default Re: (KOOL-AID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOOL-AID &raquo;</TD></TR><TR><TD CLASS="quote">why not just convert to obd-1</TD></TR></TABLE>
This in my opinion would be the best option...but get an ecu chipped for better VTEC activation point and a higher redline
Old Jun 2, 2004 | 07:22 PM
Artful Dodger's Avatar
i converted to the p28 and am obd 1. I would have to say this is the best route, the wiring is a bitch though
Old Jun 2, 2004 | 10:03 PM
CLICC916's Avatar
Default Re: (Artful Dodger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Artful Dodger &raquo;</TD></TR><TR><TD CLASS="quote">i converted to the p28 and am obd 1. I would have to say this is the best route, the wiring is a bitch though</TD></TR></TABLE>
yes obd1 wiring IS a bitch....i still haven't figured out why my dizzy's throwing a code
Old Jun 2, 2004 | 11:29 PM
mr. carpenter's Avatar
Default Re: (CLICC916)
zdyne one wire
danimin
Dec 1, 2009 02:05 PM
DsBananas94LS
Dec 5, 2004 07:51 PM
davken1102
Aug 2, 2003 06:01 PM
fasterthenmost
Sep 12, 2002 08:44 PM
Accord15
Jan 11, 2002 03:28 AM
