ITR suspension on to an ek?? HELP!!
i did a search and there were mixed ideas... so can someone tell me for sure if coilovers for a itr will fit on to an ek? i was told that you just need the rear lca to work and some say it wont work at all... HELP!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbarbulo »</TD></TR><TR><TD CLASS="quote">rear LCA from ITR don't fir EK chassis, hence ITR coilovers/shocks will NOT fit EK chassis. EKs have UNIQUE rear lower control arms.</TD></TR></TABLE>
What he said....the fronts will work but the rears won't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DuMa »</TD></TR><TR><TD CLASS="quote">quick questions.. then what do you use when you do a 5lug conversion then?</TD></TR></TABLE>
hubs, kuckles, and brakes.
its easy just replace the rear lca with integra lca's very simple. and cost effective.
i have seen it done both way's civic to teg and teg to civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed00si »</TD></TR><TR><TD CLASS="quote">its easy just replace the rear lca with integra lca's very simple. and cost effective.
i have seen it done both way's civic to teg and teg to civic.</TD></TR></TABLE>
I dont think it works that way.
The 96-00 Civic LCA is longer then the 94-01 Teg LCA.
The above info is incorrect! Here is the correct info:
92-95 EG civic and 94-01 DC integras suspension is 100% interchangable including front and rear LCA, shocks, springs, front subframe, etc. However, it's not the same case for the EK civics. Though there are common parts, the rear LCA is one of those parts where you CAN'T swap.
