Compression readings?
Old Jun 2, 2004 | 09:13 AM
deanintemp's Avatar
Default Compression readings?
Could someone please offer some advice. I am looking to purchase a 1995 used accord with 2.2L 4-cyl engine (248,000 miles). I had the car professionally inspected and car came back with very clean slate except possibly cyclinder compression tests. Compression test results were as follows: Cyl 1 = 122; Cyl 2 = 160; Cyl 3 = 165; Cyl 4 = 175. The dealer that did the inspection was reluctant to interpret the data for fear of liability!
Any help would be appreciated...
Old Jun 2, 2004 | 09:45 AM
mmuller's Avatar
Mad Scientist
Default Re: Compression readings? (deanintemp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deanintemp &raquo;</TD></TR><TR><TD CLASS="quote">Could someone please offer some advice. I am looking to purchase a 1995 used accord with 2.2L 4-cyl engine (248,000 miles). I had the car professionally inspected and car came back with very clean slate except possibly cyclinder compression tests. Compression test results were as follows: Cyl 1 = 122; Cyl 2 = 160; Cyl 3 = 165; Cyl 4 = 175. The dealer that did the inspection was reluctant to interpret the data for fear of liability!
Any help would be appreciated...</TD></TR></TABLE>
i mean with 248k miles what do you expect?
cyl# has prolly bad rings. try putting a cap of oil on that cylinder to see if compression goes up.
to see whats better going on you should do a leakdown test
Old Jun 2, 2004 | 12:15 PM
MightyMouseTech's Avatar
Default Re: Compression readings? (mmuller)
That is actually pretty bad for that mileage. She is going to be an oil burner. I have seen MANY Accords in the 400k range running 170 straight accros. The previous owner must not have changed the oil very regularily.
In short... I would walk away, unless you figure in a re-ring job.
Old Jun 2, 2004 | 01:59 PM
deanintemp's Avatar
Default Re: Compression readings? (MightyMouseTech)
He is original "mature" owner with all service records. Records are very organized and indicates oil changes regularly at 4500-4800 mile intervals. He claims the the engine runs about 1/2 quart between changes. Kelly Blue-book indicates a value of $3,300ish - I may be able to pick up for under $2,000.
Dilema, dilema
Old Jun 2, 2004 | 04:53 PM
b16supertuner's Avatar
buy it!
those guys are silly, most oil burning comes from oil seals gone bad. a car could have perfect compression and still burn oil through the valve seals.
the F motors are troopers. and cheap as hell to replace.
i give it the OK.
joey1320
Honda S2000
Feb 19, 2008 05:33 PM
dbiker207
Nov 26, 2006 07:10 AM
snowblind7x
Apr 13, 2005 08:12 PM
deanintemp
Jun 2, 2004 09:23 AM
Mr.Integra
Apr 22, 2004 07:55 PM
