bad filter
i have a CAI in my car and last night it was pouring out so much that i got scared about suckin up water so i pull my car into the garage at my work, to put the filter on only half of the intake when i loosen the middle i pull the lower part off and theres no filter on it! the seal came apart from where to the filter connects to the ruber flange. so im gonna get a new filter and i dunno if i should go back to CAI or leave it only half. whats a good filter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI »</TD></TR><TR><TD CLASS="quote">K&N!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2wickedtoyz »</TD></TR><TR><TD CLASS="quote">do you have a pic of where the filter was and connected to? also you may want to use a k&n and a bypass valve so you won't flood your motor if the h2o gets too high.</TD></TR></TABLE>
my friend had unknowingly started my car while it was pouring out. when i went outside, the car was in about 1-2 ft of water while she had started it. good thing i had a bypass or else my car woulda been
major drainage problem on my street
T_Rex
May 24, 2003 11:59 AM
