bad filter
Old Jun 2, 2004 | 05:30 AM
ekdriven's Avatar
Default bad filter
i have a CAI in my car and last night it was pouring out so much that i got scared about suckin up water so i pull my car into the garage at my work, to put the filter on only half of the intake when i loosen the middle i pull the lower part off and theres no filter on it! the seal came apart from where to the filter connects to the ruber flange. so im gonna get a new filter and i dunno if i should go back to CAI or leave it only half. whats a good filter?
Old Jun 2, 2004 | 05:34 AM
IVI's Avatar
IVI
Default Re: bad filter (deputyGSR)
K&N!
Old Jun 2, 2004 | 10:30 AM
SIK IN DA HED's Avatar
New User
weaponR foam filter
Old Jun 2, 2004 | 10:33 AM
LowTEC SaiMike's Avatar
Default Re: bad filter (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">K&N! </TD></TR></TABLE>
Old Jun 2, 2004 | 10:34 AM
2wickedtoyz's Avatar
do you have a pic of where the filter was and connected to? also you may want to use a k&n and a bypass valve so you won't flood your motor if the h2o gets too high.
Old Jun 2, 2004 | 10:44 AM
egg_baLLa's Avatar
Default Re: (2wickedtoyz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2wickedtoyz &raquo;</TD></TR><TR><TD CLASS="quote">do you have a pic of where the filter was and connected to? also you may want to use a k&n and a bypass valve so you won't flood your motor if the h2o gets too high.</TD></TR></TABLE>
my friend had unknowingly started my car while it was pouring out. when i went outside, the car was in about 1-2 ft of water while she had started it. good thing i had a bypass or else my car woulda been
major drainage problem on my street
ejmatzell
Jan 29, 2007 11:52 AM
mrdeadman
May 3, 2006 01:19 PM
red_ek_hatch
Mar 30, 2005 12:30 AM
ForceXVII
Aug 2, 2003 02:06 PM
T_Rex
May 24, 2003 11:59 AM
