to much noise in my gsr head
Old Jun 1, 2004 | 09:46 PM
dsosa51's Avatar
Default to much noise in my gsr head
it sounds like my engine is low on oil, its a lot of clicking comming from the head. someone told me that the valve seals might be bad. i donno i need some advice, what should i do, replace my valves and seals, or just seals or what???
Old Jun 1, 2004 | 11:49 PM
pbizzlegsr's Avatar
Default Re: to much noise in my gsr head (dsosa51)
is your valve cover cut off on the right side where the cam gears are?..mine has been having clicking noises also..i think its normal..bc i had a valve adjustment and its still there..sounded after the valve cover was cut
Old Jun 2, 2004 | 06:38 AM
whitelightning's Avatar
if it is the valve seals you'd see blue smoke coming out the exhaust.
i would do a valve adjustment, that should quiet it down some. good luck
Old Jun 2, 2004 | 07:20 AM
Steak84SS's Avatar
I agree with the valve adjustment. That happened on my 94 LS. It cost like 60 bucks, I think, for ACURA to do it. I didnt know how at the time.
Old Jun 2, 2004 | 07:23 AM
MasterSaif's Avatar
Default Re: to much noise in my gsr head (Steak84SS)
valve adjustment
Old Jun 2, 2004 | 07:30 AM
tilt's Avatar
gsrs are known for loud ticking injectors. do a valve lash adjustment and if the sound is still there, see if it is the injectors. it's not a problem if it is.
Old Jun 2, 2004 | 10:35 AM
dsosa51's Avatar
Default Re: to much noise in my gsr head (whitelightning)
i do have a lot of smoke comming out of my exaust do you think it could be both, the valve ajustment and the seals ??
99gsrfasho
Dec 31, 2009 10:07 PM
Ryanwill86
Feb 14, 2009 11:15 AM
DC5mike
Jun 27, 2008 06:38 PM
teamvirus
10
Oct 22, 2006 07:30 PM
Hoosier Daddy
Feb 16, 2004 01:57 PM
