2 different thrust bearings on b18a, which ones do i need?
just like the topic says i need to get new bearings and my machine shop threw the old ones. there are 2 brands, any ideas on the differences?
There are probably two sizes available (rather than two different brands). Since yours were thrown away, there is no way of knowing which size you need. I am not sure how much the bearings are. But if they are fairly inexpensive, you might get both sizes. Then try installing each set and measure crankshaft end play. Use the set that gives you crankshaft end play within specs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meanEG »</TD></TR><TR><TD CLASS="quote">come on i need to order these things. </TD></TR></TABLE>
well you need to give us more info...honda make more than 2 different sizes of bearings...
according to your block and rods, what color bearings do you need?
its not the bearings. its the thrust washers. they are not listed int he parts catalog as sizes just 2 different brands. i guess i am going to have to try both kinds. anyone have any ideas?
averyvm
Feb 28, 2007 08:29 PM
