88 civic hard to shift
Old Jun 1, 2004 | 04:25 PM
oakfall's Avatar
Default 88 civic hard to shift
Hi all,my sister gave my son an 88 Civic DL and it takes real effort to shift. Shifter very stiff. Very tough to drive.Any ideas?
Thanks,
oak
Old Jun 1, 2004 | 04:27 PM
huntarrr's Avatar
Default Re: 88 civic hard to shift (oakfall)
Was the shifter at all messed with (short shifter, etc)?
If so, check the bolt at the bottom of the shifter. It will be under the car so get your jack out.. It could be too tight. Another probable solution would be to get new shifter bushings
Old Jun 1, 2004 | 04:31 PM
oakfall's Avatar
Default Re: 88 civic hard to shift (97redex)
Thanks red,The shifter is stock and in good shape.I'm guessing I have to pull the tranny tp repair bushing? Tough job?
Thanks again
oak
Old Jun 2, 2004 | 08:28 AM
oakfall's Avatar
Can someone tel me what's involved when replacing shifter bushings in an 88 Civic DL.
Thanks,
oak
Old Jun 2, 2004 | 08:54 AM
AutoXer's Avatar
Has the fluid ever been changed? That can cause hard shifting as well.
Old Jun 2, 2004 | 09:39 AM
sohc_boy's Avatar
Default Re: 88 civic hard to shift (EX_AutoXer)
http://www.hondaautomotivepart...LEVER
here's a diagram of the shifter assy. its pretty easy to replace the bushings. also as mentioned above if the tranny's oil hasn't been changed it can cause a notchy shift.
Old Jun 2, 2004 | 10:00 AM
nonsense's Avatar
Default Re: 88 civic hard to shift (sohc_boy)
Is it har to shift when the engine is not running? If it's not then try adjusting the clutch, it may be slightly engaged even when the pedal is all the way down.
Like the others said, I'd drain the tranny fluid and refill.
Old Jun 2, 2004 | 01:09 PM
oakfall's Avatar
Thanks guys,I will change fluid and see what happens.Yes.It's just as hard shifting with engine off.
OAK
Old Jun 2, 2004 | 05:34 PM
civic_tuned's Avatar
ive changed the bushing before on my ride(poly.urathane) and it did not make a difference the shifter still gets stuck u can say but i think its something else. The shifting is stiffer and i dont likey i should of stayed with new oem bushings.
Old Jun 3, 2004 | 08:11 AM
oakfall's Avatar
Default Re: 88 civic hard to shift (civic_type_r)
Thanks for your ideas.I'm not sure what I'll do with this thing.It has no rust and seems to be in good shape.Do you think this (88 DL 2 door HB) will ever have any collector value?
gameknb
Jun 11, 2005 07:32 AM
eluder33
Nov 20, 2004 03:05 PM
jbscivichb92
Nov 18, 2004 01:03 PM
mattduskater
Jun 23, 2003 03:08 PM
Eatvtec97
May 20, 2002 12:56 PM
