engine management and emmissions....!!!
i live in NJ and the inspection station just started to hook up to the obd2 port to see if the factory ecu is there...if NOT...the you FAILED...
so what are we supposed to do???
1. Let's say i have the aem ems...and i am tuned on 18psi, 750cc injectors and 60 psi of fuel pressure...
what do i do ...install factory injectors, factory ecu and lower the fuel pressure back down to 50 psi (98 prelude specs)...and remove the wastegate spring..to prevent boost from happening???
will this even work???will i **** anything up???
this **** sux
..IMO
this **** sux
..IMOThread
injector experts please enter-injectors sizing for HP goals and fuel pressure and how they are relat
BlueShadow
Dec 9, 2005 11:11 AM
