Do I need Fmu with this setup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">I used one at 8psi on my civic. I had 310 injectors,6:1 fmu, and fuel pump. I believe you can get away without a fmu if you have a fuel pump</TD></TR></TABLE>
You going to give him $2k when he blows up his motor? LOL!
If you're going to go cheap, at least go with a proven fuel setup. AFC hack or FMU.
you should be ok up to 5 psi, but if you carank up the regulator pressure you can do more, but your car will idle like ****.
as you have the 310 cc inJ, maybe look into the uberdata fuel management.
sooner or later you'll blow up without proper fuel control.
right now I have hondata but I didnt want to tune it. I wanted to throw the kit on my daily driver till my motor is out of machine shop. well my daily driver has ls/vtec in a 94 civic coupe with pr3 piston so the compression is like 11.3. that's why I dont want to run too much boost. I think I'm just gonna borrow a fmu and run like 7 psi. thanks for your help guys.
