Fueling questions with SDS EFI...
Old Jun 1, 2004 | 07:11 AM
.RTErnie's Avatar
Default Fueling questions with SDS EFI...
My fuel system...
SDS EFI (standalone)
36# Bosch Injectors
Walbro Intank pump
t-rex inline pump
1:1 Aeromotive Regulator
-6 return system
My question is...when I start boosting the car My fuel pressure will be static at say 60psi. At idle I'll have to pull a lot of fuel, and at full boost I'll have to add a lot of fuel via the SDS. Now my thinking is...this wont be efficient for ****. And that I'll prolly need a RRFPR and go from there. Am I right in thinking this? And...another question...Would I be better off to sell my 1:1(used to set base pressure I assume) and just have a RRFPR?
Sorry for all of the dumb questions
-Eric
Old Jun 2, 2004 | 12:00 PM
.RTErnie's Avatar
Default Re: Fueling questions with SDS EFI... (Matt_sb2004)
bump
Old Jun 2, 2004 | 12:49 PM
legendboy's Avatar
ditch the 36lb injectors for some bigger ones. run stock fuel pressure.
Old Jun 2, 2004 | 02:39 PM
.RTErnie's Avatar
Default Re: Fueling questions with SDS EFI... (legendboy)
grrrr... How big then? I'm only running a 14b at the moment.
Old Jun 3, 2004 | 06:40 AM
legendboy's Avatar
well you should be able to run stock fuel pressure then! forget messing around with fuel pressure unless you are out of injector! stock is like 38? psi
Old Jun 4, 2004 | 09:48 AM
.RTErnie's Avatar
42.5...its a neon :-P
Old Jun 4, 2004 | 01:36 PM
legendboy's Avatar
a neon hey, well in that case maybe try disconecting the fuel rail fuel line and placing it near the sparkplugs and crank over j/k
the.hamburglar
Mar 27, 2015 07:58 AM
jaredvabeach
Aug 6, 2008 07:38 PM
aalb1
Nov 2, 2005 10:47 AM
Leo95SE
Jun 24, 2002 01:03 PM
Liquidx02
Mar 16, 2002 08:32 AM
