is aem uego controller compatiable with the Hondata for tuning?
Old May 31, 2004 | 03:46 PM
tspkenneth's Avatar
Default is aem uego controller compatiable with the Hondata for tuning?
nevermind i figured it out
Old Jun 5, 2004 | 04:46 PM
kamaleon's Avatar
Default Re: is aem uego controller compatiable with the Hondata for tuning? (tspkenneth)
what did u figure out?
Old Jun 19, 2004 | 03:20 PM
TurboTeG4's Avatar
Default Re: is aem uego controller compatiable with the Hondata for tuning? (kamaleon)
so is the gauge type uego compatible with hondata?
Old Jun 21, 2004 | 03:07 PM
ELAMINT5's Avatar
Default Re: is aem uego controller compatiable with the Hondata for tuning? (TurboTeG4)
so is it???
Old Jun 23, 2004 | 09:13 AM
Spunkster's Avatar
No it's not
Old Jun 29, 2004 | 11:46 AM
B00ST2nR's Avatar
Default Re: is aem uego controller compatiable with the Hondata for tuning? (Spunkster)
are you sure? I heard it work perfectly fine with Hondata.
I'm gonna tune my car with Hondata and AEM EUGO on the Dyno.
Old Jun 30, 2004 | 09:20 AM
B00ST2nR's Avatar
Default Re: is aem uego controller compatiable with the Hondata for tuning? (B00ST2nR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00ST2nR &raquo;</TD></TR><TR><TD CLASS="quote">are you sure? I heard it work perfectly fine with Hondata.
I'm gonna tune my car with Hondata and AEM EUGO on the Dyno.</TD></TR></TABLE>
Old Jun 30, 2004 | 12:16 PM
Spunkster's Avatar
NO IT WILL NOT WORK...it's voltages are out of the range the Honda ecu can use.
Old Jun 30, 2004 | 03:12 PM
B00ST2nR's Avatar
But the UEGO is a Stand Alone unit. You plug it into an O2 bung and it reads the Wideband so you can fine tune it.
I don't see why it can't be used for tuning with Hondata. The UEGO will only be on my car when I'm tuning it. After its tuned with the Hondata, the UEGO will be off.
Old Jun 30, 2004 | 03:29 PM
Rtype16's Avatar
Do you have the gauge or the UEGO controller.
Spunkster's Avatar
Thats fine a long as you are not tying to integrate it so that you can see the readings in the Hondata software. If you are not trying to interface the 2, then ANY wideband that has it's own display will work.
Old Jul 7, 2004 | 01:53 PM
jdmturbosol's Avatar
THIS IS HOW YOU FIX THE PROBLEM.
the aem wideband unit does not work with hondata.......unless
you feel like making one of these..
http://www.angelfire.com/elect...A.htm
Old Jul 7, 2004 | 02:45 PM
Rtype16's Avatar
Default Re: is aem uego controller compatiable with the Hondata for tuning? (jdmturbosol)
Just looked this over myself as well as some of the others in the electronics division here and this will work. You have to change the calibration in the Hondata, but thats it. Also if you haven't bought a UEGO controller yet. You can use the UEGO gauge(with built in controller) we have and it will work with the Hondata.
Old Jul 8, 2004 | 06:08 AM
tgreaves's Avatar
Seeing this just makes me glad I got an AEM EMS.. It can use any wideband setup on the market..
Modified by tgreaves at 9:52 AM 8/11/2004
Old Aug 11, 2004 | 12:37 AM
TurboTeG4's Avatar
Default Re: is aem uego controller compatiable with the Hondata for tuning? (tgreaves)
Does the gauge uego work with it or do you need the voltage splitter
Old Aug 11, 2004 | 05:53 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">Does the gauge uego work with it or do you need the voltage splitter </TD></TR></TABLE>
Does the uego work with what??
Old Aug 13, 2004 | 12:58 PM
TurboTeG4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmturbosol &raquo;</TD></TR><TR><TD CLASS="quote">THIS IS HOW YOU FIX THE PROBLEM.
http://www.angelfire.com/elect...A.htm</TD></TR></TABLE>
Well a lot of people are wondering if this fix works with the guage, its been posted over and over with absolutly no answers but QuaK answers
Old Aug 18, 2004 | 10:59 PM
TurboTeG4's Avatar
Old Aug 21, 2004 | 09:14 AM
TurboTeG4's Avatar
Old Aug 29, 2004 | 07:44 PM
TurboTeG4's Avatar
rfegsaefhsfgsf
projectef
Dec 16, 2006 04:56 PM
sloboy_joe
32
Nov 15, 2004 03:43 PM
B00ST2nR
Jul 7, 2004 12:15 PM
bottlefedb18c1
Jan 8, 2003 11:18 AM
uNF$@#!
Jun 19, 2002 04:03 PM
